line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Rename struct Scheduler_Control to _Scheduler_Control to allow its use
in standard header files, e.g. <pthread.h>.
Update #3112.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
Provide dedicated seize and surrender methods for inherit priority
mutexes. This eliminates CORE_mutex_Attributes.
Rework seize and surrender methods to use CORE_ceiling_mutex_Control.
This eliminates CORE_mutex_Disciplines.
Add CORE_recursive_mutex_Control and CORE_ceiling_mutex_Control to avoid
the run-time evaluation of attributes to figure out how a particular
mutex methods should behave. Start with the no protocol variants. This
eliminates the CORE_MUTEX_DISCIPLINES_FIFO and
CORE_MUTEX_DISCIPLINES_PRIORITY disciplines.
Remove superfluous support for simple binary semaphores. With this we
can get rid of the CORE_MUTEX_NESTING_BLOCKS variant.
Remove support for strict order mutexes.
Close #2124.
Remove the Thread_queue_Queue::operations field to reduce the size of
this structure. Add a thread queue operations parameter to the
_Thread_queue_First(), _Thread_queue_First_locked(),
_Thread_queue_Enqueue(), _Thread_queue_Dequeue() and
_Thread_queue_Flush() functions. This is a preparation patch to reduce
the size of several synchronization objects.
The holder field is enough to determine if a mutex is locked or not.
This leads also to better error status codes in case a
rtems_semaphore_release() is done for a mutex without having the
ownership.
We can use the holder pointer to get the identifier if necessary.
Move implementation specific parts of coremutex.h and coremutex.inl into
new header file coremuteximpl.h. The coremutex.h contains now only the
application visible API.
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013204
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
PR 1957/cpukit
* score/include/rtems/score/coremutex.h,
score/inline/rtems/score/threadmp.inl: Add parentheses to protect
macro arguments.
* score/include/rtems/score/coremutex.h: Move check dispatch for seize
into its own macro and add smp support.
* rtems/include/rtems/rtems/types.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/percpu.h,
score/include/rtems/score/rbtree.h,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Mark Score files as in Score
Group to improve Doxygen output.
PR 1777/cpukit
* libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c,
score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c,
score/inline/rtems/score/thread.inl, score/src/heapfree.c,
score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c:
Consolidated access to _Thread_Dispatch_disable_level.
* score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c:
New files.
* rtems/src/semtranslatereturncode.c,
score/include/rtems/score/coremutex.h: Returns tests to running
state.
score/inline/rtems/score/coremutex.inl, score/src/apimutexallocate.c:
Fix direction of conditional and eliminate use of nesting is error
when POSIX is disabled.
score/src/coremutexsurrender.c,
score/src/objectinitializeinformation.c: Disable code not reachable
when POSIX is not enabled.
PR 1415/cpukit
* rtems/src/semcreate.c, rtems/src/semtranslatereturncode.c,
score/inline/rtems/score/coremutex.inl, score/src/coremutex.c:
Address two paths where a task with a priority above the ceiling
could obtain a priority ceiling mutex.
* rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/status.h,
score/include/rtems/score/object.h: Removed extraneous commas.
PR 1291/cpukit
* itron/inline/rtems/itron/semaphore.inl, itron/src/twai_sem.c,
posix/include/mqueue.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/time.h, posix/src/condtimedwait.c,
posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c,
posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c,
posix/src/mutextimedlock.c, posix/src/mutextranslatereturncode.c,
posix/src/posixtimespecabsolutetimeout.c,
posix/src/semaphoretranslatereturncode.c,
posix/src/semaphorewaitsupp.c, posix/src/semtimedwait.c,
posix/src/semtrywait.c, posix/src/semwait.c,
posix/src/sigtimedwait.c, posix/src/timersettime.c,
posix/src/ualarm.c, rtems/src/semobtain.c,
score/include/rtems/score/coresem.h, score/src/coresemseize.c: This
patch addresses issues on implementation of the timeout on the
following POSIX services. Some of these services incorrectly took a
timeout as a relative time. Others would compute a 0 delta to timeout
if the absolute time and the current time were equal and thus
incorrectly block the caller forever. The root of the confusion is
that POSIX specifies that if the timeout is incorrect (e.g. in the
past, is now, or is numerically invalid), that it does not matter if
the call would succeed without blocking. This is in contrast to RTEMS
programming style where all errors are checked before any critical
sections are entered. This fix implemented a more uniform way of
handling POSIX absolute time timeouts.
+ pthread_cond_timedwait - could block forever
+ mq_timedreceive - used relative not absolute time
+ mq_timedsend - used relative not absolute time
+ pthread_mutex_timedlock - used relative not absolute time
+ pthread_rwlock_timedrdlock- used relative not absolute time
+ pthread_rwlock_timedwrlock- used relative not absolute time
+ sem_timedwait - could block forever
* score/Doxyfile: Update to latest Doxygen format.
* score/include/rtems/score/apimutex.h,
score/include/rtems/score/heap.h, score/include/rtems/score/object.h,
score/include/rtems/score/protectedheap.h,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl: Remove most doxygen
warnings.
* sapi/include/rtems/fatal.h, score/include/rtems/score/coremutex.h,
score/inline/rtems/score/thread.inl, score/src/coremutexseize.c:
Modifications to aid in full path testing.
score/src/coremutexseizeintr.c: Fix conditional code for inlining
_CORE_mutex_Seize_interrupt_trylock() and add comments.
* configure.ac, score/include/rtems/score/coremutex.h,
score/inline/rtems/score/coremutex.inl: Add the ability to disable
inlining coremutex seize. This reduces the code size and also
improves the process of coverage analysis.
* score/src/coremutexseizeintr.c: New file.
score/src/coremutexsurrender.c, score/src/threadinitialize.c: Add
support for proper stacking of priority inheritance on mutexes as
well as enforce proper order of release.
* posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/cancel.c,
posix/src/conddestroy.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c,
posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspindestroy.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c,
rtems/src/timerfireafter.c, score/include/rtems/system.h,
score/include/rtems/score/coresem.h: Restructed to move the
OBJECTS_LOCAL case to the top of the switch statement and
eliminate the fall-through return of POSIX_BOTTOM_REACHED. These
changes produced simplier assembly code and allowed for complete
test coverage. Also applied some consistency to the functions
that translate the core status codes to POSIX status codes.
* posix/src/mutextranslatereturncode.c,
posix/src/semaphoretranslatereturncode.c: New files.
* posix/src/mutexfromcorestatus.c: Removed.
PR 1222/cpukit
* score/Makefile.am, score/include/rtems/score/coremutex.h,
score/inline/rtems/score/coremutex.inl, score/src/coremsgsubmit.c,
score/src/coremutexsurrender.c, score/src/threadchangepriority.c,
score/src/threadclearstate.c, score/src/threadhandler.c,
score/src/threadinitialize.c, score/src/threadqdequeuefifo.c,
score/src/threadqextractfifo.c, score/src/threadqextractpriority.c,
score/src/threadsetstate.c: Enhance so that when the prioirity of a
thread that is blocked on a priority based thread queue is changed,
that its placement in the queue is reevaluated based upon the new
priority. This enhancement includes modifications to the SuperCore as
well as new test cases.
* score/src/threadqrequeue.c: New file.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h,
score/include/rtems/seterr.h, score/include/rtems/system.h,
score/include/rtems/score/copyrt.h,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working
modifications which are not complete and may have broken code.
Committing so work and testing can proceed.
* score/Doxyfile, score/mainpage.h: New files.
