* include/bsp.h: New header guard.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* console/led.S: Include <rtems/asm.h> instead of <asm.h>.
* start/start.S: Include <rtems/asm.h> instead of <asm.h>.
* startup/idtmem.S: Include <rtems/asm.h> instead of <asm.h>.
* startup/idttlb.S: Include <rtems/asm.h> instead of <asm.h>.
* times, include/bsp.h, startup/bspstart.c: Convert to using c99
fixed size types.
* console/console.c, include/bsp.h, include/coverhd.h,
startup/bspclean.c, startup/bspstart.c, startup/setvec.c: URL for
license changed.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
added prototypes.
Derrick Ostertag (ostertag@transition.com).
