summaryrefslogtreecommitdiff
path: root/c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (follow)
AgeCommit message (Collapse)Author
2002-09-032002-09-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* base_mp now builds and can be considered a bit of an example for the other mptests. * mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, samples/base_mp/mptest.adb, samples/base_mp/mptest.ads, samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am: Modified to make compile. * mptests/mp01/node1/mptest-per_node_configuration.adb, mptests/mp01/node2/mptest-per_node_configuration.adb, mptests/mp02/node1/mptest-per_node_configuration.adb, mptests/mp02/node2/mptest-per_node_configuration.adb, mptests/mp03/node1/mptest-per_node_configuration.adb, mptests/mp03/node2/mptest-per_node_configuration.adb, mptests/mp04/node1/mptest-per_node_configuration.adb, mptests/mp04/node2/mptest-per_node_configuration.adb, mptests/mp05/node1/mptest-per_node_configuration.adb, mptests/mp05/node2/mptest-per_node_configuration.adb, mptests/mp06/node1/mptest-per_node_configuration.adb, mptests/mp06/node2/mptest-per_node_configuration.adb, mptests/mp07/node1/mptest-per_node_configuration.adb, mptests/mp07/node2/mptest-per_node_configuration.adb, mptests/mp08/node1/mptest-per_node_configuration.adb, mptests/mp08/node2/mptest-per_node_configuration.adb, mptests/mp09/node1/mptest-per_node_configuration.adb, mptests/mp09/node2/mptest-per_node_configuration.adb, mptests/mp10/node1/mptest-per_node_configuration.adb, mptests/mp10/node2/mptest-per_node_configuration.adb, mptests/mp11/node1/mptest-per_node_configuration.adb, mptests/mp11/node2/mptest-per_node_configuration.adb, mptests/mp12/node1/mptest-per_node_configuration.adb, mptests/mp12/node2/mptest-per_node_configuration.adb, mptests/mp13/node1/mptest-per_node_configuration.adb, mptests/mp13/node2/mptest-per_node_configuration.adb, mptests/mp14/node1/mptest-per_node_configuration.adb, mptests/mp14/node2/mptest-per_node_configuration.adb, samples/base_mp/node1/mptest-per_node_configuration.adb, samples/base_mp/node2/mptest-per_node_configuration.adb: Removed as this information should come from config.h.
1997-06-02modified copyright notice to be the same as RTEMS 4.0.0.Joel Sherrill
changed the CVS ID string to be a "development" version.
1997-06-02Initial revisionJoel Sherrill
