summaryrefslogtreecommitdiff
path: root/automake/host.am (follow)
AgeCommit message (Collapse)Author
2018-01-25Remove make preinstallChris Johns
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2006-01-12Remove depend-am:Ralf Corsepius
2003-08-182003-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius
* automake/local.am, automake/host.am: Remove "debug".
2003-05-272003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius
PR 321: * aclocal/check-bsp-cache.m4: Remove support for profile-variant. * aclocal/env-rtemsbsp.m4 * automake/compile.am * automake/host.am * automake/local.am
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill
