summaryrefslogtreecommitdiff
path: root/VERSION (follow)
AgeCommit message (Collapse)Author
2015-05-21Top files: Update and prep for release branchJoel Sherrill
2012-05-11Remove CVS Id Strings (manual edits after script)Joel Sherrill
These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
2011-02-28Bump.Joel Sherrill
2008-10-012008-10-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* VERSION: Bump version to 4.9.99.0
2007-09-212007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* VERSION: Bump VERSION to 4.8.99.0.
2007-08-07Upgrade to 4.7.99.2Joel Sherrill
2007-03-13Upgrade to 4.7.99.1Joel Sherrill
2007-02-22Revert to version 4.7.99-0Ralf Corsepius
2007-02-22Testing: Upgrade to 4.7.99.1Ralf Corsepius
2007-02-152007-02-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* VERSION: Sync with version in aclocal/version.m4.
2006-04-182006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-4.6.99.3.
2005-09-022005-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-4.6.99.2.
2004-07-282004-07-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-4.6.99.1.
2004-02-122004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius
* VERSION: 4.6.99.0. * aclocal/version.m4: 4.6.99.0.
2003-12-172003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-20031217-test.
2003-07-032003-07-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20030703.
2003-04-172003-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20030417.
2003-04-112003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20030411.
* VERSION: Updated to rtems-ss-20020411.
2003-01-282003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20030128.
2002-11-182002-11-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20021118.
2002-11-112002-11-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20021111.
2002-10-212002-10-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-20021021-test.
2002-10-072002-10-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20021007.
2002-10-042002-10-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-JUNK.
* VERSION: Updated to rtems-ss-20021004.
2002-03-082002-03-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-mg5-20020808.
2002-03-012002-03-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20020301.
2002-02-152002-02-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20020215.
2002-02-052002-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20020205.
2002-01-182002-01-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20020118.
* VERSION: Updated to rtems-20020118.
2002-01-172002-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* VERSION: Updated to rtems-ss-20020717.
2001-12-07changed version to ss-20011210Joel Sherrill
2001-12-03changed version to ss-20011203Joel Sherrill
2001-10-25changed version to ss-20011025Joel Sherrill
2001-10-17changed version to ss-20011017Joel Sherrill
2001-10-05changed version to ss-20011005Joel Sherrill
2001-08-16changed version to ss-20010816Joel Sherrill
2001-08-16changed version to eng-20010816Joel Sherrill
2001-07-12changed version to ss-20010712Joel Sherrill
2001-07-06changed version to ss-20010706Joel Sherrill
2001-05-25changed version to ss-20010525Joel Sherrill
2001-05-25changed version to mg5-20010525Joel Sherrill
2001-04-24changed version to ss-20010424Joel Sherrill
2001-03-26changed version to ss-20010326Joel Sherrill
2001-03-19changed version to ss-20010319Joel Sherrill
2001-01-26changed version to ss-20010126Joel Sherrill
2001-01-26changed version to ss-20000126Joel Sherrill
