2012-07-31 | Add ARM support. Cleaned up the waf support. | Chris Johns | |
Adding ARM support has changed the architecture relocation interface. All architectures updated. Cleaned up the RTEMS waf support to only look for tools when the arch is being processed. Add filter support to allow a user to make sure a BSP is present or to remove BSPs that will not build. Added the Init support because ARM BSPs do not contain the support. | |||
2012-07-16 | Resolve unresolved externals when loading object files. | Chris Johns | |
Object files that depend on each other will cause an unresolved external. The change lets object files load with unresolved externals and will resolve them when the object file with the external is loaded. A common table of symbol strings and relocation records is maintained. The symbol string is shared by each object file that is unresolved. Each relocation record that references the symbol is held. The table is a series of small blocks that compact as symbols are resolved. The number of symbols left unresolved is typically small this design avoids fragmentation of the heap memory. | |||
2012-05-07 | Update copyright year. Remove the Id tag. | Chris Johns | |
2012-04-25 | Import the current project to git. | Chris Johns | |
