2014-08-07 | rtms-tld: Refactor the code to match a better configuration format. | Chris Johns | |
2014-08-04 | rtems-tld: Add generator loading support. | Chris Johns | |
2014-08-04 | rtems-tld: Add recursive parsing of headers and defines. | Chris Johns | |
2014-08-04 | rtems-tld: Add trace configuration support. | Chris Johns | |
Extend the configuration support to provide the needed configuration required to generate the C stub support. | |||
2014-08-01 | Add initial support for the RTEM Trace Linker. | Chris Johns | |
The RTEMS Trace Linker or rtems-rld creates an RTEMS executable with trace support built in without any changes the existing code. This commit is an initial starting point with function signatures being read from INI files. |
