2014-09-06 | Refactor the CC flags. Fix the various linkers. The trace linker is compiling. | Chris Johns | |
2014-09-01 | rld: Split the file into a path module for path specific functions. | Chris Johns | |
This allows resued for other parts of the system not dependent on objcet files or archives. | |||
2014-08-05 | Fix temporary file handling and add tempfile write support. | Chris Johns | |
Move the static objects into the rld-process file and change the clean up to a call. Add support to write to tempfiles. | |||
2013-03-01 | Fix the trace help. | Chris Johns | |
2012-11-26 | Update to the latest framwork requirements. | Chris Johns | |
2012-11-21 | Remove the warning about the warnings option on newer gccs. | Chris Johns | |
2012-11-19 | Only look for standard library paths if standard libraries and enabled. | Chris Johns | |
2012-11-17 | Refactor the ELF support to allow ELF write suppport. | Chris Johns | |
The refactoring allows better reuse of the ELF support and cleans up some hacks from the generic file and archive handling improving the separation of the file handling from the file format, ie ELF. The handling of ELF object files and ELF object files inside archives is cleaner. The refactor cleaned up the symbol handling where the symbols now reside in the ELF file object and references are take in symbol pointer containers and symbol table containers. The main purpose of the refactor is to allow support for creating and writing ELF files. Also added an rtems-syms command where special symbol support can be added. |
