This allows resued for other parts of the system not dependent on
objcet files or archives.
When passing shorhand options, getopt_long sometimes does not handle
them correctly.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Move the static objects into the rld-process file and change the
clean up to a call.
Add support to write to tempfiles.
rtems-ra supports converting an elf archive file into a rap archive file.
It also support add, replace and delete rap files from the rap archive
file.
