2014-09-10 | Make the verbose take the level and return the level if valid. | Chris Johns | |
This makes the verbose a single and removes the need to have the logic of the test in the code. | |||
2014-09-09 | linkers: If no RTEMS path is provied see if the prefix can be used. | Chris Johns | |
2014-09-08 | RTEMS trace linker builds trace applications. | Chris Johns | |
The trace linker builds the both_hello example in examples-v2. Move the various string support functions into a C++ file and stop being inlined. Make them return const std::string. Add ld support to rld-cc. Add search path support to rld-config so installed common files can be used. Fix the path bugs. Add an absolute path function to rld-path. | |||
2014-09-07 | Refactor the rld-rtems support to remove the globals. | Chris Johns | |
2014-09-07 | rtems-tld: Add --wrapper option to aid testing. | Chris Johns | |
The --wrapper option lets a user control the wrapper file name and location to aid testing. Add keep support to tempfiles so specific tempfile can be set to be kept. Add unlink to the rld::path namespace. | |||
2014-09-06 | Add a path str. Remove the duplicate split call. | Chris Johns | |
2014-09-05 | Add support for RTEMS BSP or user supplied CFLAGS. Remove march/mcpu. | Chris Johns | |
Added support to read an RTEMS BSP pkgconfig file and ste the CC flags. | |||
2014-08-07 | rtms-tld: Refactor the code to match a better configuration format. | Chris Johns | |
2014-08-05 | rtems-tld: Add wrapper support and start the generator coding. | Chris Johns | |
2014-08-04 | rtems-tld: Add generator loading support. | Chris Johns | |
2014-08-04 | rtems-tld: Add recursive parsing of headers and defines. | Chris Johns | |
2014-08-04 | rtems-tld: Add trace configuration support. | Chris Johns | |
Extend the configuration support to provide the needed configuration required to generate the C stub support. | |||
2012-12-18 | Add a new trace level. | Chris Johns | |
2012-11-26 | Split trace to have without and with symbols. | Chris Johns | |
2012-05-07 | Add to git. | Chris Johns | |
