Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
This avoids test durations of more than one hour on fast targets, since
fast targets can count a lot during one clock tick period, so the minor
loop iteration count was quite high. Estimate now the test body
duration to iterate only through the interesting time window.
Add and use interrupt_critical_section_test().
The changes in _Thread_Dispatch() of commits
dad36c52b8be5d7b46bc7af85655055db7208652 and
d4dc7c8196355f08044e67a3f5c1e19485f17ff1 introduced a severe bug which
destroys the real-time properties of RTEMS completely.
Consider the following scenario. We have three tasks L (lowest
priority), M (middle priority), and H (highest priority). Now let a
thread dispatch from M to L happen. An interrupt occurs in
_Thread_Dispatch() here:
void _Thread_Dispatch( void )
post_switch:
_ISR_Enable( level );
<-- INTERRUPT
<-- AFTER INTERRUPT
_Thread_Unnest_dispatch();
_API_extensions_Run_postswitch();
The interrupt event makes task H ready. The interrupt code will see
_Thread_Dispatch_disable_level > 0 and thus doesn't perform a
_Thread_Dispatch(). Now we return to position "AFTER INTERRUPT". This
means task L executes now although task H is ready! Task H will execute
once someone calls _Thread_Dispatch().
