Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Deprecate Classic API Notepads. Mark task_set/get_note() with
the deprecated attribute, and also mark the notepads field.
Replace disable with enable option for notepads in confdefs.h,
and make notepads disabled by default. The previous option
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and
will emit a compile-time warning. A new option
CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn
on notepads, but it also will emit a compile-time warning
to indicate that notepads are deprecated.
Closes #2265
Provide a file per BSP to list tests that do not build for a BSP. This change
removes the BSP_SMALL_MEMORY hack from the code. That hack was a
mistake.
Provide configuration files for each BSP with tests that cannot build.
This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be.
for details.
LINK_OBJS =
instead of
LINK_OBJS = $(mp01_node1_OBJECTS)
PR 1589/build
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Remove obsolete
optional manager capability.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
* mp01/init.c, mp01/task1.c, mp02/init.c, mp02/task1.c, mp03/delay.c,
mp03/init.c, mp03/task1.c, mp04/init.c, mp04/task1.c, mp05/asr.c,
mp05/init.c, mp05/task1.c, mp06/init.c, mp06/task1.c, mp07/init.c,
mp07/task1.c, mp08/init.c, mp08/task1.c, mp09/init.c, mp09/recvmsg.c,
mp09/sendmsg.c, mp09/task1.c, mp10/init.c, mp10/task1.c, mp10/task2.c,
mp10/task3.c, mp11/init.c, mp12/init.c, mp13/init.c, mp13/task1.c,
mp13/task2.c, mp14/delay.c, mp14/evtask1.c, mp14/evtmtask.c,
mp14/exit.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c,
mp14/smtask1.c: Add HAVE_CONFIG_H.
* mp03/task1.c, mp10/init.c, mp13/task1.c: Use
rtems_clock_get_ticks_per_second() instead of the obsoleted
TICKS_PER_SECOND.
* mp01/init.c, mp02/init.c, mp02/task1.c, mp03/init.c,
mp04/init.c, mp05/init.c, mp06/init.c, mp07/init.c,
mp08/init.c, mp09/init.c, mp09/task1.c, mp10/init.c,
mp11/init.c, mp12/init.c, mp13/init.c, mp14/init.c:
Use PRI*32 to print uint32_ts.
* mp04/task1.c: Include "tmacros.h".
Use PRIxrtems_task_priority to print rtems_task_prioritys.
* mp05/asr.c: Include "tmacros.h".
Use PRIxrtems_signal_set to print rtems_signal_set's.
Use PRIxrtems_signal_set to print rtems_signal_sets.
* mp01/task1.c, mp02/task1.c, mp03/task1.c, mp05/task1.c, mp06/task1.c,
mp07/task1.c, mp08/task1.c, mp09/recvmsg.c, mp09/sendmsg.c,
mp09/task1.c, mp10/init.c, mp12/init.c, mp13/init.c, mp13/task1.c,
mp13/task2.c, mp14/evtask1.c, mp14/init.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* mp01/task1.c, mp01/node1/mp01-node1.scn, mp01/node2/mp01-node2.scn:
Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_TOD,
..) to rtems_clock_get_tod(..).
Eliminate _exe_/.exe.
* mp09/recvmsg.c, mp09/task1.c, mp10/task1.c, mp13/task1.c,
mp14/msgtask1.c: Correct types to eliminate warnings.
* mp14/delay.c, mp14/evtmtask.c: Pass task Id to TSR.
* mp14/system.h: Semaphore_task_id and Semaphore_task_name arrays
were one entry too short.
* mp03/delay.c, mp06/task1.c, mp06/node2/mp06-node2.scn, mp07/task1.c:
Updating and fixing while running them on psim.
* mp05/system.h, mp05/task1.c, mp06/system.h, mp06/task1.c,
mp07/system.h, mp07/task1.c, mp14/evtask1.c, mp14/evtmtask.c,
mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c,
mp14/system.h: Convert to bool type.
* mp01/init.c, mp02/init.c, mp03/init.c, mp04/init.c, mp05/init.c,
mp06/init.c, mp07/init.c, mp08/init.c, mp09/init.c, mp10/init.c,
mp11/init.c, mp12/init.c, mp13/init.c, mp14/init.c: Change TEST_INIT
to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a
clock_settime case for < 1988.
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Use all managers.
* mp02/task1.c, mp14/delay.c: Add new Object Services collection. This
changed the name of a few previously public but undocumented services
and added a some new services.
* mp12/node2/mp12-node2.scn: Redo screen to not have cvs conflict
marker.
