for details.
PR 1708/build:
* aclocal/check-cpuopts.m4: Fix m4-quoting.
* aclocal/check-cpuopts.m4: Add AC_LANG_SOURCE.
* aclocal/check-cpuopts.m4: Check rtems/system.h instead of
rtems/score/cpuopts.h.
check cpuopts.h.
* aclocal/check-cpuopts.m4: New.
