- Pick up the Beatnik support for the legacy driver
Keep RTEMS up to date with the upstream development.
The original version of this patch had a conflict between the two
interrupts where the program-viewable interrupt state could be
deasserted when it should have been asserted. The new version of this
patch resolves that conflict.
This temporarily adds a patch to fix badly behaving CGEM peripherals
under QEMU. The referenced patch has been submitted for inclusion in
the upstream QEMU repository.
Updates #4919
- Zynq ARM fixes
- AARCH64 MMU fix
- Updated imxrt drivers
- x86_64 EFI support
- Flash driver
- Updated validation tests
- Microblaze updates
- Add getaddrinfom, gai_strerror, ipv6_addr, if_nametoindex and BSD programs
- Update sysctl
- Move legacy net
Previously newlib only had long double math functions when the
sizeof(double) was equal to sizeof(long double). Newlib now includes
support for true long double on x86, x86_64, and aarch64.
These files were not included in the previous commit.
The change leaves the encoding in that currently exists because
I cannot remember why it is there. If an encoding error happens
return the same path to see if it will work.
The source URL for Xilinx QEMU appears to have been incorrect from the
start. Since we are cloning a git repository, we should use 'git://'.
Update #4560.
- Tools picks up the stm32h7-stlink to handle SIGTRAP fix.
- RTEMS picks up the motorola_powerpc updates including the mvme2700
BSP and Makefile.inc fixes for building EPICS.
- Legacy networking picks up a number of build system fixes,
network configuration changes and more tests.
- Build GNU sed for hosts that it is not installed on for the MIPS
tools.
- MacOS systems do not come with makeinfo
- Fix the internal build logic. There was config logic in a
bset file that does not support logic operators. Use a
special tmp internal path to isolate the internal tools.
Closes #4894
Note:
GCC does not build on MacOS 13.3 due to the specific version
of GCC the Microblaze is using.
Updates #4892
- Use a build set file to stage GMP as recent GDB
versions require GMP.
Update #4892
- This is a place holder incase we stop building MPFR in
GCC.
Updates #4892
- Use base64 checksums
- Change MPFR URL
Updates #4892
Updates #4892
- Do not build GMP when building GCC. GMP is now built
as a package for GDB. Building as a separate package
lets use control how it is built.
Updates #4892
- Detect and use a virtual environment if present
- Supports MacOS with python.org in a venv
Updates #4892
Updates #4892
Binutils 2.39 and later enable by default warnings for executables
with executable stack and RWX sections. Disable them.
Closes #4881
Binutils 2.40 has a regression for AArch64 that has previously been
fixed. See https://sourceware.org/bugzilla/show_bug.cgi?id=27217
This regression causes at least 2 tests to fail to build.
GDB 11.2 fails to compile on Ubuntu 22.04 for MicroBlaze.
See https://sourceware.org/bugzilla/show_bug.cgi?id=30214
Closes #4872
