2018-12-26 | Fix python3 print problem. | Chris Johns | |
2018-12-09 | Remove outdated instructions and change sis to erc32 | Marçal Comajoan Cara | |
This work was part of GCI 2018. | |||
2018-01-18 | wscript: fix default version from 4.12 to 5 | Gedare Bloom | |
2017-10-12 | Add C11 Threading Examples | Joel Sherrill | |
2017-10-02 | Update rtems_waf to use the rootfs support. Fix trace linker INI files. | Chris Johns | |
Use the rtems_waf rootfs support to create a root file system. Remove the double cflags on some projects that broke linking. Remove the dump-on-error, there is no option in rtems-tld. Closes 3158. Closes 3159. | |||
2013-12-13 | User friendly error message if the rtems_waf module is not included. | Chris Johns | |
2013-12-12 | cxx: Add support for building with waf | Chirayu Desai | |
2013-12-12 | posix_api: Add support to build with waf | Chirayu Desai | |
Add wscript(s) for building with waf | |||
2013-12-12 | micromonitor: umon: Add support to build with waf | Chirayu Desai | |
Add wscript to support building with waf Build it only for csb337 BSP (ARM) | |||
2013-12-12 | benchmarks: Add support to build with waf | Chirayu Desai | |
Add wscript(s) to support building benchmarks/nbench with waf | |||
2013-12-12 | Convert misc/minimum example to Waf. | Bryan Dunsmore | |
2013-12-12 | Convert led/timer example to Waf. | Bryan Dunsmore | |
2013-12-12 | Convert uboot example to use Waf. | Bryan Dunsmore | |
2013-12-12 | Convert ticker example to use Waf. | Bryan Dunsmore | |
2013-12-12 | Convert gdb example to use Waf. | Bryan Dunsmore | |
2013-12-12 | added wscript to file_io and subdirectories | Daniel Ramirez | |
2013-12-12 | Added wscript to clasic_api directory | Daniel Ramirez | |
2013-12-12 | waf: add optimization and debug flags to top-level wscript | Gedare Bloom | |
2013-12-12 | filesystem: initial attempt at waf conversion | Gedare Bloom | |
2013-12-12 | Add LICENSE.2 with 2-clause BSD. Point to it from 2-clause BSD licensed files. | Gedare Bloom | |
2013-12-12 | hello: Add support to build with waf. | Gedare Bloom | |
Add wscript support for building hello/hello_world_c with waf. | |||
2013-12-12 | Waf: Add top-level wscript and rtems_waf module to support waf builds. | Gedare Bloom | |
