2017-10-12 | Update due to trace linker changes | Sebastian Huber | |
Close #3160. | |||
2017-10-02 | Update rtems_waf to use the rootfs support. Fix trace linker INI files. | Chris Johns | |
Use the rtems_waf rootfs support to create a root file system. Remove the double cflags on some projects that broke linking. Remove the dump-on-error, there is no option in rtems-tld. Closes 3158. Closes 3159. | |||
2016-04-13 | fat_ramdisk: define POSIX keys number | Peng Fan | |
define POSIX KEYS and PAIRS to 16, otherwise met: " pthread_setspecific(shell_current_env_key) " | |||
2014-09-22 | Add more trace builds for other examples. | Chris Johns | |
2014-09-05 | Clean up warnings. | Chris Johns | |
2013-12-12 | Fix rtems.py's filtering of BSPs. | Chris Johns | |
Update the BSP filtering in the RTEMS waf support. Break the flags down even more to allow users to manage what they use in applications. Add rtems-bin2c to the list of checked tools. | |||
2013-12-12 | filesystem: minor fixes | Gedare Bloom | |
2013-12-12 | filesystem: Update wscript. compiles now to make it better | Gedare Bloom | |
2013-12-12 | filesystem: initial attempt at waf conversion | Gedare Bloom | |
2013-03-12 | examples-v2: Remove .cvsignore files | Joel Sherrill | |
2012-05-15 | examples-v2 - Remove CVS Ids (scripted) | Joel Sherrill | |
2011-03-14 | 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* crc/Makefile, fat_ramdisk/Makefile: Fix Makefiles. | |||
2011-03-11 | 2011-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* fat_ramdisk/.cvsignore, fat_ramdisk/Makefile, fat_ramdisk/README, fat_ramdisk/init.c, fat_ramdisk/rootfs/shell-init: New files. |
