Unlike the older build this keeps files within each BSP now that we have a
one-directory-per-bsp model.
This supports external BSPs trivially by keeping all files separate from
the base build.
This BSP family uses only one linker command file. Use the standard
name.
Update #3818.
name.
Update #3818.
Update #3818.
Use the test state configuration instead.
Update #3818.
Update #3818.
name.
Update #3818.
name.
Update #3818.
Update #3785.
It is fine to build the drivers always.
Update #3818.
The small page MMU support reduces the granularity for memory settings
through the MMU from 1MiB sections to 4KiB small pages.
Enable it by default on the realview_pbx_a9_qemu BSP.
Bug was introduced by commit 1e1afa3779e594e09387fba1812d3028fb00cd9e.
LLVM/LLD does not support STARTUP and ALIGN_WITH_INPUT directives that
GNU LD support. INPUT and ALIGN(8) are supported by LLVM/LLD and can
replace the unsupported STARTUP/ALIGN_WITH_INPUT directives.
The commit conditionally adds the supported directive that linkers
can understand depending on the toolchain used to compile RTEMS
i.e., clang or gcc. Clang is assumed to use LLD by default.
This commit moves the existing linkcmds.base to linkcmds.base.in
in order to make it configurable by autotools.
Use NULL-pointer protection also for Qemu variant.
Do all calculations in the linker command file. This is a preparation
for the new build system.
Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board.
Update #3785.
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
Add support for _SMP_Send_message() to the own processor. This is
required by the smpmulticast01 test program.
- Update the linkcmd file to support configure settings
- Set the workspace size based on the revision value
- Port the jbang code from C++ to C to enable DBGEN.
- Hook the libdebugger ARM backend support to return the base address
of the debug register set.
This fixes the corruption of r3 by the call to
bsp_start_arm_drop_hyp_mode().
Moving the code makes it easier to review changes in start.S.
Close #3773.
This makes it easier to review changes in start.S.
Update #3773.
- Allow the RTEMS_ROOT to be conditionally supplied. This
can be a staging area before being moved to the final
install prefix location.
- Update the default.cfg to use RTEMS_ROOT and to not rely on
the exec_prefix so it's paths can be staged.
- Fix and add the needed configure subs.
Closes #3768
controller support.
Update #3269.
Update #3725.
Remove this BSP option.
Modifications to get xilinx-zynqmp BSP working on an Ultra96 board.
Update #3682.
Source files were copied from xilinx-zynq.
Update #3682.
This driver will be shared with the xilinx-zynqmp BSP.
Update #3682.
Change license to BSD-2-Clause.
Close #3725.
This gets rid of a special include path.
Update #3678.
Update #3678.
Close #3667.
Update #3254.
In order to simplify the use of CPU counter values it is beneficial to
have monotonic increasing values within the range of the CPU counter
ticks data type, e.g. 32-bit unsigned integer. This eases the use of
CPU counter timestamps in external tools which do not know the details
of the CPU counter hardware. The CPU counter is the fastest way to get
a time on an RTEMS system.
Such a CPU counter may be also used as the timecounter. Use it on SPARC
for this purpose to simplify the clock drivers.
Update #3456.
Update #3459.
Move start.o to separate file.
Update #3459.
Update #3599.
Avoid dependencies on the Termios support in case only printk() is used
by the application.
x86_64 is 64-bits and too new for the legacy stack to support.
epiphany is a small target and cannot compile the legacy (or new) stack.
Close #3375.
