2010-07-31 | 2010-07-31 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* automake/compile.am: Remove clean-local:. Use CLEANFILES for cleaning up make-exe by-products. | |||
2009-10-23 | 2009-10-23 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* automake/compile.am: Add *.ralf to clean-local. | |||
2005-11-22 | Remove .obj | Ralf Corsepius | |
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* automake/compile.am: Remove .coff. | |||
2005-11-13 | Remove depend. | Ralf Corsepius | |
2005-11-13 | Remove preinstall, preinstall-recursive. | Ralf Corsepius | |
2005-11-13 | Remove preinstall-am. | Ralf Corsepius | |
2005-11-13 | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* automake/compile.am: Remove LINK_OBJS. Remove LINK_FILES. Remove ARCH. Remove LINK_LIBS. Extend clean-local to catch most temporary files make-exe is creating. | |||
2005-11-09 | Assume PROJECT_ROOT to contain RTEMS_BSP. | Ralf Corsepius | |
2005-11-09 | Eliminate PROJECT_LIB. | Ralf Corsepius | |
Remove START_FILE, OBJS from LINK_FILES. | |||
2005-11-08 | Remove RTEMS_CPPFLAGS, RTEMS_CFLAGS, RTEMS_CXXFLAGS. | Ralf Corsepius | |
2005-11-08 | Cleanup. | Ralf Corsepius | |
2005-11-08 | Remove RTEMS_BSP_SPECS, GCC_SPECS. | Ralf Corsepius | |
Don't manually set up GCCSPEC (Now setup from inside configure). Remove RTEMS_RELLDFLAGS (Used). | |||
2005-11-08 | Remove CCAS support. | Ralf Corsepius | |
2005-11-07 | Remove depend-am. | Ralf Corsepius | |
2005-11-07 | Remove depend. | Ralf Corsepius | |
2005-11-07 | Remove depend-recursive. | Ralf Corsepius | |
2005-11-07 | Take contents of amcompile.am. | Ralf Corsepius | |
2005-11-07 | Remove | Ralf Corsepius | |
2005-11-07 | New. | Ralf Corsepius | |
2005-01-06 | 2004-01-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* automake/compile.am: Remove CLEANDIRS (Unused). Remove DEFS (Implicitly handled by automake). | |||
2005-01-06 | Remove duplicate CCAS. | Ralf Corsepius | |
* automake/compile.am: Remove CONFIG.CC (Unused). Remove CPPFLAGS, CFLAGS, CXXFLAGS, ASFLAGS (Implicitly handled by automake). Add CCAS. Use AM_*FLAGS = RTEMS_*FLAGS. Remove LIB_VARIANT from LINK_*. Cleanup comments. | |||
* automake/compile.am: Remove AS, ASCOMPILE, make-rel (Unused). Remove build-variants. Hard-code ARCH=o-optimize. | |||
2004-04-20 | Remove stray white spaces. | Ralf Corsepius | |
2003-12-17 | 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* automake/compile.am: Use $(mkdir_p) instead of $(mkinstalldirs). | |||
2003-12-15 | 2003-12-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* aclocal/env-rtemsbsp.m4: Add PROJECT_LIB. * automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. | |||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* automake/compila.am: Remove ARCH. | |||
2003-12-01 | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* automake/compile.am: Add $(ARCH)/$(dirstamp) rules. * aclocal/lead-dot.m4: New (from automake-1.7f). * aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT. Add AC_SUBST(dirstamp). | |||
2003-08-17 | 2003-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* automake/local.am, automake/host.am: Remove "debug". | |||
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* automake/compile.am, automake/host.am, automake/leaf.am automake/local.am, automake/subdirs.am: New (copied from ../../../automake). |
