Update #3382
Update #3182.
Updates #2859
disabled
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
Add POSIX shared memory manager (Shm). Includes a hook-based
approach for the backing memory storage that defaults to the
Workspace, and a test is provided using the heap. A test is
also provided for the basic use of mmap'ing a shared memory
object. This test currently fails at the mmap stage due to
no support for mmap.
Add pthread_getname_np() and pthread_setname_np().
Update #2858.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
updates #2608.
This is the very simple implementation specified by the Open Group
for implementations with 1:1 kernel thread to user thread mappings.
http://pubs.opengroup.org/onlinepubs/9699919799/functions/pthread_getconcurrency.html
updates #2680.
Closes #2182
Ensure that the global construction is performed in the context of the
first initialization thread. On SMP this was not guaranteed in the
previous implementation.
Provide a file per BSP to list tests that do not build for a BSP. This change
removes the BSP_SMALL_MEMORY hack from the code. That hack was a
mistake.
Provide configuration files for each BSP with tests that cannot build.
Formerly POSIX keys were only enabled when POSIX threads
were enabled. Because they are a truly safe alternative
to per-task variables in an SMP system, they are being
enabled in all configurations.
This patch enables unlimited model in POSIX key manger and have a decent
runtime on POSIX key searching, adding and deleting operations. Memory
overhead is lower than current implementation when the size of key and key
value becomes big.
for details.
* psxconfig01/.cvsignore, psxconfig01/Makefile.am, psxconfig01/init.c,
psxconfig01/psxconfig01.doc, psxconfig01/psxconfig01.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
PR 1855/cpukit
* Makefile.am, configure.ac: Correct signal processing during
pthread_join. We are supposed to unblock the thread waiting on a
pthread_join(), dispatch the signal handler, account for it
potentially overwriting errno, and then have the thread return to
blocking within pthread_join().
* psxeintr_join/.cvsignore, psxeintr_join/Makefile.am,
psxeintr_join/init.c, psxeintr_join/psxeintr_join.doc,
psxeintr_join/psxeintr_join.scn: New files.
PR 1867/cpukit
* Makefile.am, configure.ac, psx12/task.c, psxkey03/init.c,
psxrwlock01/test.c: Correct implementation of pthread_exit() and
pthread_join() to support the case where a thread is joinable but
calls pthread_exit() before a thread has attempted to join.
* Makefile.am: Remove EXTRA_DIST.
Remove DIST_SUBDIRS.
Remove obsolete comments.
PR 1759/cpukit
* Makefile.am, configure.ac: Add test to use some pthread calls with
Classic Tasks.
* psxclassic01/.cvsignore, psxclassic01/Makefile.am,
psxclassic01/init.c, psxclassic01/psxclassic01.doc,
psxclassic01/psxclassic01.scn: New files.
* Makefile.am, configure.ac: Add psxaio03/.
* psxaio03/Makefile.am, psxaio03/init.c, psxaio03/psxaio03.scn
psxaio03/system.h: New.
* Makefile.am, configure.ac: New test to ensure pthread_cond_wait() and
sleep() (e.g. interruptible blocking and sleeping) are interruptible
by signal.
* psxsignal06/.cvsignore, psxsignal06/Makefile.am, psxsignal06/init.c,
psxsignal06/psxsignal06.doc, psxsignal06/psxsignal06.scn: New files.
* Makefile.am, configure.ac, psx07/init.c, psx07/psx07.scn,
psxhdrs/Makefile.am, psxstack01/init.c: Add pthread_attr_getstack,
pthread_attr_setstack, pthread_attr_getguardsize, and
pthread_attr_setguardsize.
* psxstack02/.cvsignore, psxstack02/Makefile.am, psxstack02/init.c,
psxstack02/psxstack02.doc, psxstack02/psxstack02.scn: New files.
* psx15/.cvsignore, psx15/Makefile.am, psx15/init.c, psx15/psx15.scn:
New files.
* Makefile.am, configure.ac: Add psxaio01/, psxaio02/.
* psxaio01/Makefile.am, psxaio01/init.c, psxaio01/psxaio01.scn,
psxaio01/system.h: New.
* psxaio02/Makefile.am, psxaio02/init.c, psxaio02/psxaio02.scn,
psxaio02/system.h: New.
PR 1642/testing
* psximfs02/init.c, psximfs02/psximfs02.scn,
psximfs02/psximfs02.doc, psximfs02/Makefile.am: New test added.
* configure.ac, Makefile.am: Changes to accommodate psximfs02
test.
PR 1613/testing
* psxfchx01/init.c, psxfchx01/Makefile.am, psxfchx01/.cvsignore,
psxfchx01/psxfchx01.doc, psxfchx01/psxfchx01.scn: New
tests. Improves coverage of fchdir, fchmod, fchown directives.
* configure.ac, Makefile.am: Changes to accommodate new test.
* psxstat/test.c, psxstat/psxstat.scn: Added new test case to test
statvfs routine under libcsupport.
PR 1610/testing
* psx13/test.c, psx13/psx13.scn: Remove the test cases which
exercise pipe. These are new a new test under psxpipe01/
* psxpipe01/init.c, psxpipe01/Makefile.am,
psxpipe01/psxpipe01.scn, psxpipe01/psxpipe01.doc: Added new test.
* Makefile.am, configure.ac: Changes due to addition of new test:
psxpipe01.
* Makefile.am, configure.ac: Add test for various forms of times() and
getrusage().
* psxgetrusage01/.cvsignore, psxgetrusage01/Makefile.am,
psxgetrusage01/init.c, psxgetrusage01/psxgetrusage01.doc,
psxgetrusage01/psxgetrusage01.scn, psxtimes01/.cvsignore,
psxtimes01/Makefile.am, psxtimes01/init.c, psxtimes01/psxtimes01.doc,
psxtimes01/psxtimes01.scn: New files.
PR 1598/testing
* Makefile.am, configure.ac, psxpasswd01/init.c,
psxpasswd01/psxpasswd01.doc, psxpasswd01/psxpasswd01.scn: Add testing
for POSIX user database (e.g. /etc/group and /etc/passwd) access
routines which are implemented in libcsupport/src/getpwent.c.
* psxpasswd02/.cvsignore, psxpasswd02/Makefile.am, psxpasswd02/init.c,
psxpasswd02/psxpasswd02.doc, psxpasswd02/psxpasswd02.scn: New files.
* Makefile.am, configure.ac: Add tests for file lock stubs as well as
various POSIX methods that access UID, PID, and GID.
* psxfilelock01/.cvsignore, psxfilelock01/Makefile.am,
psxfilelock01/init.c, psxfilelock01/psxfilelock01.doc,
psxfilelock01/psxfilelock01.scn, psxid01/.cvsignore,
psxid01/Makefile.am, psxid01/init.c, psxid01/psxid01.doc,
psxid01/psxid01.scn: New files.
* Makefile.am, configure.ac: Add test to exercise IMFS behaviour with
files of maximum sizes.
* psximfs01/.cvsignore, psximfs01/Makefile.am, psximfs01/init.c,
psximfs01/psximfs01.doc, psximfs01/psximfs01.scn: New files.
* Makefile.am, configure.ac: Revert accidentally committed patch.
* Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am,
psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am,
psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am,
psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am,
psxalarm01/Makefile.am, psxautoinit01/Makefile.am,
psxautoinit02/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxcancel01/Makefile.am,
psxchroot01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c,
psxfile02/psxfile02.doc, psxfile02/psxfile02.scn,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxsignal02/Makefile.am, psxsignal03/Makefile.am,
psxsignal04/Makefile.am, psxsignal05/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am,
psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater
than number of file descriptors configured.
* Makefile.am, configure.ac: Added test case for calls that check for
an unopened file descriptor.
* psxfile02/.cvsignore, psxfile02/Makefile.am, psxfile02/init.c,
psxfile02/psxfile02.doc, psxfile02/psxfile02.scn: New files.
* psx13/test.c, psx13/psx13.scn Added new routine PipeTestNull()
to cover the trivial NULL case for pipe function.
* Makefile.am, configure.ac: New test to exercise getgrnam and getpwnam
families.
* psxpasswd01/.cvsignore, psxpasswd01/Makefile.am, psxpasswd01/init.c,
psxpasswd01/psxpasswd01.doc, psxpasswd01/psxpasswd01.scn: New files.
PR 1466/tests
* Makefile.am, configure.ac, psxclock/init.c, psxclock/psxclock.doc,
psxclock/psxclock.scn, psxkey03/init.c, psxsignal02/init.c,
psxsignal03/init.c, psxstack01/init.c: Remove usleep() from tests.
Add test specifically to test it since it is deprecated as of
POSIX.1-2008.
* psxusleep/.cvsignore, psxusleep/Makefile.am, psxusleep/init.c,
psxusleep/psxusleep.doc, psxusleep/psxusleep.scn: New files.
* Makefile.am: Build file IO related tests even with POSIX threading is
disabled.
* psxcleanup/system.h: Fix typo.
* Makefile.am, configure.ac: Add new test for exercising pushing
and popping a clean up handler without actually executing it.
* psxcleanup01/.cvsignore, psxcleanup01/Makefile.am,
psxcleanup01/init.c, psxcleanup01/psxcleanup01.doc,
psxcleanup01/psxcleanup01.scn: New files.
