summaryrefslogtreecommitdiff
path: root/INSTALL (follow)
AgeCommit message (Collapse)Author
2013-04-23README: Update README and INSTALL to try to be GNU'ish.Gedare Bloom
2012-05-11Remove CVS Id Strings (manual edits after script)Joel Sherrill
These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
2000-02-08Updated.Joel Sherrill
1998-01-15Fixed code for --disable-rtems-inlines so that it would completeJoel Sherrill
configuration successfully. Added code to detect configuring macros and POSIX API at the same time. There is no macro implementation for the POSIX API.
1997-04-25Updated to point to README.configure for build instructions.Joel Sherrill
1995-05-11Initial revisionJoel Sherrill
