path: root/irq_test_c/Makefile (follow)
* 2009-09-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-09-171-3/+3
| | | | | | | | | | | | * Makefile.shared, networkconfig-qemu.h, cpuuse/Makefile, empty/Makefile, empty/empty.adb, exception_test2/Makefile, exception_test2/exceptiontest2.adb, exception_test3/Makefile, exception_test3/exceptiontest3.adb, hello_via_task/Makefile, hello_via_task/hello.adb, irq_test_c/Makefile: Make follow standard RTEMS test output format. Add output screens where appropriate. * exception_test2/exception_test2.scn, exception_test3/exception_test3.scn, hello_via_task/hello_via_task.scn: New files.
* 2007-10-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-10-171-0/+27
* Makefile, Makefile.shared, rtems_init.c, irq_test/interrupt_pkg.adb, irq_test/interrupt_pkg.ads, irq_test/irqforce.c, irq_test/irqtest.adb, rootfs/etc/hosts: Adding new tests as improvements are made to the RTEMS port of the GNAT run-time. * empty/Makefile, empty/README, empty/empty.adb, hello_via_task/.cvsignore, hello_via_task/Makefile, hello_via_task/hello.adb, irq_test/.cvsignore, irq_test/Makefile, irq_test/README, irq_test_c/.cvsignore, irq_test_c/Makefile, irq_test_c/README, irq_test_c/init.c, irq_test_c/irqforce.c: New files.
