* Makefile.shared, networkconfig-qemu.h, cpuuse/Makefile,
empty/Makefile, empty/empty.adb, exception_test2/Makefile,
exception_test2/exceptiontest2.adb, exception_test3/Makefile,
exception_test3/exceptiontest3.adb, hello_via_task/Makefile,
hello_via_task/hello.adb, irq_test_c/Makefile: Make follow standard
RTEMS test output format. Add output screens where appropriate.
* exception_test2/exception_test2.scn,
exception_test3/exception_test3.scn,
hello_via_task/hello_via_task.scn: New files.
* Makefile.shared, hello_via_task/hello.adb: Make follow standard RTEMS
test output format.
* Makefile.shared, hello_via_task/.cvsignore: Update or add .cvsignore.
* empty/.cvsignore, exception_test2/.cvsignore,
exception_test3/.cvsignore: New files.
* Makefile, Makefile.shared, rtems_init.c, irq_test/interrupt_pkg.adb,
irq_test/interrupt_pkg.ads, irq_test/irqforce.c,
irq_test/irqtest.adb, rootfs/etc/hosts: Adding new tests as
improvements are made to the RTEMS port of the GNAT run-time.
* empty/Makefile, empty/README, empty/empty.adb,
hello_via_task/.cvsignore, hello_via_task/Makefile,
hello_via_task/hello.adb, irq_test/.cvsignore, irq_test/Makefile,
irq_test/README, irq_test_c/.cvsignore, irq_test_c/Makefile,
irq_test_c/README, irq_test_c/init.c, irq_test_c/irqforce.c: New files.
