* Makefile.shared: Add -g.
* Makefile.shared: Adjust for removal of RTEMS_BSP_FAMILY.
* Makefile.shared, networkconfig-qemu.h, cpuuse/Makefile,
empty/Makefile, empty/empty.adb, exception_test2/Makefile,
exception_test2/exceptiontest2.adb, exception_test3/Makefile,
exception_test3/exceptiontest3.adb, hello_via_task/Makefile,
hello_via_task/hello.adb, irq_test_c/Makefile: Make follow standard
RTEMS test output format. Add output screens where appropriate.
* exception_test2/exception_test2.scn,
exception_test3/exception_test3.scn,
hello_via_task/hello_via_task.scn: New files.
* Makefile.shared, hello_via_task/hello.adb: Make follow standard RTEMS
test output format.
* Makefile.shared, hello_via_task/.cvsignore: Update or add .cvsignore.
* empty/.cvsignore, exception_test2/.cvsignore,
exception_test3/.cvsignore: New files.
* Makefile.shared: (pc386) Make sure .exe is file to run.
* Makefile.shared: Update Makefiles.
* Makefile.shared: Ignore .svn also.
* Makefile.shared: Add -g. Leave temporary files for debug.
* rtems_init.c: zero out workspace and heap automatically. This
is required by the GNAT run-time.
* Makefile.shared, rtems_init.c: More clean up and more generalization.
* Makefile, Makefile.shared, rtems_init.c, irq_test/interrupt_pkg.adb,
irq_test/interrupt_pkg.ads, irq_test/irqforce.c,
irq_test/irqtest.adb, rootfs/etc/hosts: Adding new tests as
improvements are made to the RTEMS port of the GNAT run-time.
* empty/Makefile, empty/README, empty/empty.adb,
hello_via_task/.cvsignore, hello_via_task/Makefile,
hello_via_task/hello.adb, irq_test/.cvsignore, irq_test/Makefile,
irq_test/README, irq_test_c/.cvsignore, irq_test_c/Makefile,
irq_test_c/README, irq_test_c/init.c, irq_test_c/irqforce.c: New files.
* Makefile.shared: Change bin2c to rtems-bin2c.
* Makefile: Add stack_check test.
* Makefile.shared: Add EXTRA_GNATFLAGS so stack_check can specify
the flags -fstack-check.
* ChangeLog: New tests. Clean up. Rework so all tests use the same
shared Makefile for the hard logic of producing an executable.
* Makefile, Makefile.shared, README.Makefiles, networkconfig.h,
rtems_init.c: New files.
