* | 6/rtems-gcc: Revert to the gcc-13 release branch for MacOS fixesHEADmaster | Chris Johns | 2024-04-14 | 2 | -4/+4 |
| | | | | | Change back to gcc-13 branch and a git version as gcc-13.2 does not build on MacOS 14.4. The fixes are on the gcc-13 release branch. | ||||
* | rtems: Checksum fixes | Chris Johns | 2024-04-14 | 1 | -4/+4 |
| | | | | Updates #4991 | ||||
* | qemu-xilinx: Update to 2023.2 | Kinsey Moore | 2024-04-04 | 2 | -1/+38 |
| | | | | | | | The 2020.2 version of Xilinx's qemu branch does not build on AArch64 due to a merge conflict that was integrated into the repository and never corrected. This brings qemu-xilinx up to 2023.2 to resolve that issue and allow it to build on AArch64 systems. | ||||
* | glib: Update to 2.56.4 | Kinsey Moore | 2024-04-04 | 5 | -3/+34 |
| | | | | This updates glib to 2.56.4 for AArch64 build support. | ||||
* | sb: Add sb-rtems-pkg to update the RTEMS package hashes and checksums | Chris Johns | 2024-04-04 | 4 | -1/+332 |
* | rtems: Update RTEMS packages to their HEAD | Chris Johns | 2024-04-03 | 3 | -7/+7 |
* | rtems-gcc-*-newlib-head.cfg: Bump hash for newlib | Joel Sherrill | 2024-03-14 | 6 | -12/+12 |
| | | | | | This was driven by the increase in fdset size from 64 to 256 files. | ||||
* | rtems-tools-6.cfg: Bump hash to account for 5 months of changes | Joel Sherrill | 2024-03-14 | 1 | -2/+2 |
| | | | | | | In particular, the BSP set definitions for rtems-bsp-builder were out of sync with RTEMS and caused unnecessary failures reported to the build@ mailing list. | ||||
* | rtems: Checksum fixes | Chris Johns | 2024-02-20 | 3 | -5/+5 |
* | devel/qemu-xilinx: Fix build on GCC 13.2.0 | Kinsey Moore | 2024-02-19 | 1 | -0/+7 |
| | | | | | GCC 13.2.0 adds new warnings/errors when mixing ints and enums. This changes the pminsn helper type to correctly use enums. | ||||
* | gcc: gcc-4.9-1.cfg Make-lang patch checksum error | Chris Johns | 2024-02-19 | 1 | -1/+1 |
* | Update libtool to 2.4.7 for AArch64 support | Kinsey Moore | 2024-02-12 | 3 | -2/+19 |
* | qemu: Update CFLAGS and LDFLAGS overrides | Kinsey Moore | 2024-02-04 | 1 | -2/+2 |
| | | | | | QEMU used to honor LDFLAGS and CFLAGS and has since moved to accepting them via --extra-cflags and --extra-ldflags options to configure. | ||||
* | source-builder: Handle modern pkg-config symlinks | Kinsey Moore | 2024-02-04 | 2 | -0/+6 |
| | | | | | | | | Modern versions of pkg-config include new architecture-specific symlinks that are sometimes checked before "pkg-config". This causes builds to detect the system pkg-config instead of the local overridden pkg-config and fail to build properly. This overrides those new symlinks to restore build functionality. | ||||
* | bare/config/qemu-5.2.0: Add gdbus-codegen patch | Kinsey Moore | 2024-01-31 | 1 | -0/+7 |
* | bare/or1ksim: Fix invalid hash and fix the version | Chris Johns | 2023-12-13 | 2 | -4/+6 |
* | print/texinfo: Check the version and build if too old | Chris Johns | 2023-12-13 | 1 | -1/+9 |
| | | | | | Packages like binutils need newer versions than available by default on MacOS. | ||||
* | sb: Set the uid and gid on POSIX systems | Chris Johns | 2023-12-07 | 1 | -1/+5 |
| | | | | | | This improves performance because it avoids an exec each time the _uid macro is referenced and that can be a number of times for each config parsed. | ||||
* | sb: Allow _ in downloaded file names | Chris Johns | 2023-12-07 | 1 | -2/+2 |
* | hash: Fix missing hashes after errors if missing | Chris Johns | 2023-12-07 | 15 | -62/+134 |
* | gdb: Add options to control the python version | Chris Johns | 2023-11-30 | 1 | -0/+19 |
| | | | | | | | | | The options are: --with-python2 --with-python3 --with-python-version Closes #4973 | ||||
* | sb: No hash on a package is an error | Chris Johns | 2023-11-30 | 1 | -3/+1 |
* | 6: Fix gcc-13 support for MacOS | Chris Johns | 2023-11-28 | 6 | -9/+67 |
| | | | | Update #4921 | ||||
* | rtems/rtems-tools: Update with C++17 and Python 3.12 fixes | Chris Johns | 2023-11-24 | 1 | -2/+2 |
| | | | | | Updates #4969 Updates #4970 | ||||
* | 6: Use Binutils 2.41 | Sebastian Huber | 2023-11-22 | 2 | -1/+14 |
| | | | | | | Prepare for RTEMS 6.1 release. Update #4921. | ||||
* | 6: Use GCC 13.2 | Sebastian Huber | 2023-11-22 | 1 | -1/+1 |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2023-11-22 | 3 | -6/+6 |
| | | | | Keep RTEMS up to date with the upstream development. | ||||
* | 6: Update GCC 12 and 13 | Sebastian Huber | 2023-11-22 | 2 | -4/+4 |
* | 6/7: Update Newlib | Sebastian Huber | 2023-11-22 | 6 | -12/+12 |
| | | | | | | | | Pick up fixes for ARM/optimized-routines and the memory reclamation at thread exit. Update #4510. Update #4967. | ||||
* | sb: Fix Python 3.12 safeConfigParser and invalid escape sequences | Chris Johns | 2023-11-22 | 2 | -3/+3 |
| | | | | Updates #4968 | ||||
* | rtems-mipstx39-gdb-head.bset: Add missing file | Joel Sherrill | 2023-11-17 | 1 | -0/+7 |
| | | | | | | | This configuration file was missing for the mipstx39 gdb build for the head/7 tools. Closes #4935. | ||||
* | sb/linux.py: More reliably recognize distribution | Michael South | 2023-11-17 | 1 | -30/+59 |
| | | | | | | | If available, use "distro" package (introduced Python 3.6, back-ported to 2.6) to recognize Linux distributions and versions. Updates #4966 | ||||
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2023-10-18 | 3 | -6/+6 |
* | 6: Add GCC 13.2 configuration | Sebastian Huber | 2023-10-18 | 1 | -0/+20 |
* | rtems/net-legacy: Update to latest | Chris Johns | 2023-10-15 | 1 | -2/+2 |
| | | | | Pick up the test printer header change | ||||
* | rtems/net-services: Update to latest | Chris Johns | 2023-10-15 | 1 | -2/+2 |
| | | | | - Updates for the RTEMS test changes | ||||
* | rtems/libbsd: Update to latest | Chris Johns | 2023-10-15 | 1 | -2/+2 |
| | | | | - Pick up fixes to x86 (i368) bus space usage in kernel DMA | ||||
* | rtems/kernel: Update to latest | Chris Johns | 2023-10-15 | 1 | -2/+2 |
| | | | | | | | | - libdl: fix TLS in base image - bsps/xnandpsu: fixes - cpukit/jffs2: avoid dead lock - bsps/imxrt: enable USB and fix PHY clock enable - bsps/stm32h7: update STM32 H7 HAL | ||||
* | rtems/tools: Update to latest | Chris Johns | 2023-10-15 | 1 | -2/+2 |
| | | | | Minor fix in rtems-test | ||||
* | 6: Update GCC 12 and 13 | Sebastian Huber | 2023-10-12 | 2 | -4/+4 |
* | 6/7: Update Newlib | Sebastian Huber | 2023-10-12 | 5 | -26/+10 |
| | | | | | | Pick up latest changes from ARM/optimized-routines. Close 4510. | ||||
* | qemu: Adjust cgem interrupt patch | Kinsey Moore | 2023-10-07 | 3 | -4/+14 |
| | | | | | | | | | This patch is being moved to the 5.2.0-1 QEMU configuration because the Xilinx QEMU build uses the 5-1 configuration and this patch does not apply to Xilinx's modified tree. This also adds a new patch that applies correctly to Xilinx's modified QEMU tree. Updates #4919 | ||||
* | rtems/tools: Execute use of shlex.join fix for python < 3.8 | Chris Johns | 2023-08-31 | 1 | -2/+2 |
| | | | | Updates #4951 | ||||
* | rtems/tools: Shell execute fixes | Chris Johns | 2023-08-29 | 1 | -2/+2 |
* | rtems/tools: Pick up the rtems-syms and rtems-test sis changes | Chris Johns | 2023-08-21 | 1 | -2/+2 |
| | | | | Updates #4920 | ||||
* | testproc/gsed: update from 4.8 to 4.9. | Karel Gardas | 2023-08-05 | 2 | -1/+13 |
| | | | | Fixes #4938. | ||||
* | rtems/kernel: Update to the current kernel | Chris Johns | 2023-07-26 | 1 | -2/+2 |
| | | | | - Pick up the Beatnik support for the legacy driver | ||||
* | 6: Use libexpat 2.5.0 | Sebastian Huber | 2023-07-24 | 4 | -3/+23 |
| | | | | | | This version contains security fixes. Prepare for RTEMS 6.1 release. Update #4921. | ||||
* | 6: Use GDB 13.2 | Sebastian Huber | 2023-07-24 | 3 | -2/+19 |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2023-07-20 | 3 | -6/+6 |
