This disables any usage of the on-device R/W cache since all device
cache maintenance functions are compiled out under RTEMS leaving no way
to flush the cache before system reset and making data loss possible.
Some drivers can't easily work with buffers that are not cache aligned
and have an arbitrary length. Therefore use an aligned malloc instead.
The rtems_bsd_mmcsd_attach_worker acquired the bus without releasing it.
If a MMC device has multiple hardware partitions (like eMMC which
typically has at least one boot partition) the
rtems_bsd_mmcsd_attach_worker would try to acquire the bus multiple
times. This doesn't work.
Doing it right would mean to acquire and release the bus for each
access which would have an performance impact. Beneath that it would
mean that partition switching has to be supported by the RTEMS code too.
There is currently no known use case where the access would be
necessary. Therefore this patch prefers the performance and just avoids
all further hardware partitions.
Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a.
Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319.
Update #3472.
Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9.
Update #3472.
Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1.
Update #3472.
Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c.
Update #3472.
The following files are now provided by Newlib:
* arpa/inet.h
* net/if.h
* netinet/in.h
* netinet/tcp.h
* sys/socket.h
* sys/uio.h
* sys/un.h
The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be
used directly.
Update #2833.
Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f.
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
