* | items: Add ItemMapper.copyrights_by_license | Sebastian Huber | 2023-11-21 | 1 | -0/+3 |
| | | | | | Register the copyrights by license in the ItemMapper. This allows getting an aggregated copyright information from the item mapper. | ||||
* | items: Add Link order | Sebastian Huber | 2023-11-21 | 1 | -0/+6 |
* | items: Add ItemMapper.scope() | Sebastian Huber | 2023-11-21 | 1 | -0/+8 |
* | rtems: Add Item.initialize_links() | Sebastian Huber | 2023-06-14 | 1 | -5/+3 |
* | rtems: Add Item.create_item() | Sebastian Huber | 2023-06-14 | 1 | -4/+7 |
* | items: Return the UIDs of the loaded items | Sebastian Huber | 2023-06-14 | 1 | -11/+18 |
* | items: Add ItemCache.set_types() | Sebastian Huber | 2023-06-14 | 1 | -3/+14 |
* | items: Derive ItemCache from dict | Sebastian Huber | 2023-06-14 | 1 | -17/+9 |
* | items: Return empty type string by default | Sebastian Huber | 2023-06-14 | 1 | -0/+1 |
* | items: Allow item loading on demand | Sebastian Huber | 2023-06-14 | 1 | -8/+14 |
* | items: Add link_is_enabled() | Sebastian Huber | 2023-06-14 | 1 | -0/+5 |
* | Update company name | Sebastian Huber | 2023-05-19 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | items: Add Item.spec_2 | Sebastian Huber | 2023-05-08 | 1 | -0/+9 |
* | items: Remove ${spec} substitution | Sebastian Huber | 2023-05-08 | 1 | -14/+9 |
* | items: Use CSafeLoader if available | Sebastian Huber | 2023-05-08 | 1 | -1/+6 |
* | items: Add "initialize-links" option to ItemCache | Sebastian Huber | 2023-05-08 | 1 | -2/+3 |
* | items: Add proxy item type | Sebastian Huber | 2023-05-08 | 1 | -0/+43 |
* | items: Yield only links of enabled items | Sebastian Huber | 2023-05-08 | 1 | -38/+68 |
* | items: Add enabled set to ItemCache | Sebastian Huber | 2023-05-08 | 1 | -5/+40 |
* | items: Move key path resolution to ItemMapper | Sebastian Huber | 2023-05-08 | 1 | -33/+24 |
* | validation: Derive names from item UIDs | Sebastian Huber | 2023-02-16 | 1 | -2/+16 |
| | | | | | Use the item UID converted to CamelCase for Doxygen group names and testsuite names. | ||||
* | Replace type comment with ":" annotation | Sebastian Huber | 2023-01-03 | 1 | -9/+9 |
* | pylint: Disable no-self-use | Sebastian Huber | 2023-01-03 | 1 | -4/+0 |
| | | | | This check is optional in version 2.14. | ||||
* | Changes for pylint 2.13.9 | Sebastian Huber | 2023-01-03 | 1 | -3/+3 |
* | Format with yapf version 0.32.0 | Sebastian Huber | 2023-01-03 | 1 | -0/+8 |
* | items: Add items by type to item cache | Sebastian Huber | 2022-09-28 | 1 | -0/+2 |
* | items: Add create_unique_link() | Sebastian Huber | 2022-09-02 | 1 | -0/+13 |
* | items: Use SHA256 for digest | Sebastian Huber | 2022-07-29 | 1 | -2/+3 |
* | items: Add data_digest() | Sebastian Huber | 2022-07-29 | 1 | -3/+8 |
* | items: Remove debug output | Sebastian Huber | 2022-07-28 | 1 | -1/+0 |
* | items: Simplify code | Sebastian Huber | 2022-07-28 | 1 | -6/+4 |
* | items: Add JSONItemCache | Sebastian Huber | 2022-07-28 | 1 | -19/+72 |
* | rtemsspec: Fix augment_with_test_links() | Sebastian Huber | 2022-07-27 | 1 | -1/+5 |
| | | | | Add also parent links. | ||||
* | rtemsspec: Module for RTEMS specification details | Sebastian Huber | 2022-07-27 | 1 | -3/+10 |
* | items: Add ItemGetValueContext.arg() | Sebastian Huber | 2022-04-11 | 1 | -0/+9 |
* | items: Add support for arguments in substitutions | Sebastian Huber | 2021-10-01 | 1 | -7/+22 |
* | items: Remove support for pipe substitution | Sebastian Huber | 2021-10-01 | 1 | -7/+4 |
* | items: Add ItemMapper.get_value_dictionary() | Sebastian Huber | 2021-09-30 | 1 | -6/+28 |
* | items: Add ItemCache.types | Sebastian Huber | 2021-05-28 | 1 | -3/+11 |
* | items: Fix item used for the UID mapping | Sebastian Huber | 2021-02-09 | 1 | -4/+4 |
* | items: Improve identifier to value error message | Sebastian Huber | 2021-01-22 | 1 | -2/+7 |
* | items: Improve identifier to item error message | Sebastian Huber | 2021-01-22 | 1 | -3/+8 |
* | items: Add Item parent_link() and child_link() | Sebastian Huber | 2020-12-15 | 1 | -19/+45 |
* | items: Improve substitution error messages | Sebastian Huber | 2020-12-14 | 1 | -2/+10 |
* | items: Fix ItemCache construction | Sebastian Huber | 2020-12-14 | 1 | -5/+5 |
| | | | | | Use a separate cache directory for each specification item base directory. | ||||
* | items: Simplify ItemMapper | Sebastian Huber | 2020-12-13 | 1 | -34/+40 |
* | items: Optional post-process load in ItemCache | Sebastian Huber | 2020-12-13 | 1 | -9/+11 |
* | items: Remove unused ItemCache.top_level | Sebastian Huber | 2020-12-13 | 1 | -8/+0 |
* | items: Add Item.digest() | Sebastian Huber | 2020-12-13 | 1 | -0/+31 |
* | items: Catch all YAML errors | Sebastian Huber | 2020-12-02 | 1 | -2/+2 |
