For checking the dependencies, the tests are removed. But if the tests
are not enabled at all, that triggers a python exception.
During some newlib version, the _types_fd_set has been replaced with
just fd_set.
Since the epoch call callbacks may lock/unlock a mutex the callbacks must be
called from within thread context with thread dispatching enabled. Use thread
pinning to ensure that the calling thread stays on the right processor. Use
the interrupt server to ensure the thread context for the epoch drain.
Use the PER_CPU_DATA_NEED_INITIALIZATION() macro if necessary to request an
initialization of the per-CPU data.
Changed nfs_utime() to nfs_utimens(), changed the arguments to use
a timespec array instead of individual variables for access and
modified time.
Updates #4400
setkey uses pfkey_open to open a socket. But setkey doesn't close the
socket.
The libipsec functions are used only by user space applications (setkey
and racoon). Adding the wrapper for socket makes sure that the opened
socket is registered and closes if the application exits.
Fixes #4405
Adds "rtems,path" as an additional bus path for the i2c driver.
Previously the bus path was provided in "rtems,i2c-path" property
only.
Possible data sources for SD driver:
- mmc_sd_switch():
- length: 64 byte;
- buffer on stack
- mmc_test_bus_width():
- length: 4 or 8 byte
- buffer in program memory or on stack
- mmc_app_send_scr():
- length: 8 byte
- buffer from device ivar structure
- mmc_app_sd_status():
- length: 64 byte
- mmc_send_ext_csd():
- length: MMC_EXTCSD_SIZE = 512
- rtems_bsd_mmcsd_disk_read_write():
- length: depends on read
- buffer from rtems_blkdev buffer -> already aligned
- mmcsd_ioctl_cmd():
- length: depends on call
- buffer malloced, not aligned -> patched in RTEMS
So the problematic buffers are only the ones up to 512 bytes. Copy these data
into a buffer to avoid that problem.
Some drivers can't easily work with buffers that are not cache aligned
and have an arbitrary length. Therefore use an aligned malloc instead.
This reverts commit 1b07480ddc93c10777eff5072e7621ed0c96d30c.
The files have been taken from RTEMS repository with head commit at
bd9e45d91f77657445400bc2c814f251c9e37cef
Update #4372
Update #4372
Update #4372
This is basically the same as the patch for ping.
Update #4360
Dynamically allocate a big enough file descriptor set for select(). A
better solution would be to use kqueue() instead of select().
Update #4360
The TI driver has been moved to RTEMS so the driver can be removed
from libBSD.
The following files have been removed from libBSD and moved to
RTEMS.
1) ti/am335x/am335x_scm_padconf.c
2) ti/am335x/am335x_scm_padconf.h
3) ti/ti_pinmux.c
4) ti/ti_pinmux.h
Update #3784
Updates #4264
Updates #4264
hmac_md5 is defined in dhcpcd and in wpa supplicant.
With the previous fix, it could happen that the end of the packet hasn't
been flushed. For example assume the following addresses:
ds_addr: 0x81c804A
ds_len: 0x57
In that case the data ends at 0x81c80a1. But due to the rounding the
area from 0x81c8040 to 0x81c80a0 would have been flushed.
This fix now first calculates the start and end address, aligns these
addresses and then recalculates the len that has to be flushed.
Update #4180
Update #4180
Update #3910.
Update #3910.
Update the host frame interval after a device connection. Select also
the FS/LS PHY clock. It is not clear if this works on all platforms.
Update #3910.
Update #3910.
Close #4164.
Update #4164.
- The files in the i386 directory have been moved to common x86 directories by FreeBSD:
- freebsd/sys/i386/include/machine/bus.h
- freebsd/sys/x86/include/machine/legacyvar.h
- freebsd/sys/x86/include/machine/specialreg.h
- Add header files in rtemsbsd directory to direct compiler to new files
- cpusets and SMP are currently not supported in libbsd for RTEMS
- Disable the ifc_cpus context variable and replace its usage,
essentially hard-coding for cpu 0
