2017-01-11 | rtems-bsd-mutex: Add SMP lock debug supportfreebsd-9.3 | Sebastian Huber | |
2017-01-11 | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | |
2017-01-09 | Workaround for <sys/event.h> update | Sebastian Huber | |
2016-12-23 | Update due to Newlib 2.5.0 | Sebastian Huber | |
2016-12-23 | PIPE(2): Port to RTEMS | Kevin Kirspel | |
2016-12-23 | PIPE(2): Import from FreeBSD | Kevin Kirspel | |
2016-12-15 | Add BRIDGE(4) support to configuration | Sebastian Huber | |
2016-12-07 | pfctl: Update due to linker set API changes | Sebastian Huber | |
2016-11-29 | debugger: Set the fd to -1 to indicate being disconnected. | Chris Johns | |
2016-11-29 | Add a RTEMS Debugger TCP remote transport. | Chris Johns | |
The patch also adds support to libbsd's build system making source conditional on a configure check. The debugger support is not available on all architectures and this feature lets us test if is avaliable. | |||
2016-11-24 | ftpd: Use floating-point tasks due to syslog() | Sebastian Huber | |
2016-11-24 | SLEEPQUEUE(9): Properly remove timeout timer | Sebastian Huber | |
2016-11-24 | Use _Thread_Dispatch_direct() | Sebastian Huber | |
2016-11-24 | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | |
2016-11-14 | Use -Wno-pointer-sign | Sebastian Huber | |
Pointer sign warnings are quite common in FreeBSD code. | |||
2016-11-14 | Fix errno redefined warning | Sebastian Huber | |
2016-11-14 | Fix mbuf_jumbo_alloc() | Sebastian Huber | |
2016-11-14 | Revert "rtems-kernel-page: Panic on recursive reclaim" | Sebastian Huber | |
This attempt to fix a memory allocation problem turned out to be broken. This reverts commit 651710509430eee6731807801bd5ad85d28f4db4. | |||
2016-11-10 | Fix default network memory configuration | Sebastian Huber | |
2016-11-10 | rtems-kernel-page: Panic on recursive reclaim | Sebastian Huber | |
2016-11-09 | SDHCI(4): Delete | Sebastian Huber | |
Delete heavily modified SDHCI(4) support. It must be re-imported from a later FreeBSD version on demand. | |||
2016-11-09 | Provide O_CLOEXEC | Sebastian Huber | |
2016-11-09 | Provide CLOCK_UPTIME | Sebastian Huber | |
2016-11-09 | Add thread fences to <machine/atomic.h> | Sebastian Huber | |
2016-11-09 | Fix warnings for linker sets | Sebastian Huber | |
2016-11-09 | Modify rtems_bsd_set_vprintf_handler() | Sebastian Huber | |
Return previous vprintf()-handler in rtems_bsd_set_vprintf_handler(). | |||
2016-11-09 | Add empty <machine/_kernel_lock.h> | Sebastian Huber | |
2016-11-09 | rtems-bsd-mutex: Optimize | Sebastian Huber | |
Inline SMP lock acquire/release. Avoid stack frame for hot path. | |||
2016-11-09 | Really robust linker sets | Sebastian Huber | |
The previous attempt to fix this issue failed. See also: https://gcc.gnu.org/ml/gcc/2016-09/msg00114.htm | |||
2016-11-03 | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | |
2016-10-26 | More robust linker sets | Sebastian Huber | |
See also: https://gcc.gnu.org/ml/gcc/2016-09/msg00114.html | |||
2016-10-26 | Prepare copyiniov() for FreeBSD update | Sebastian Huber | |
2016-10-26 | devfs: Fix includes | Sebastian Huber | |
2016-10-24 | rtemsbsd: Add reallocf to rtems_bsd_program. | Christian Mauderer | |
2016-10-24 | Add SIZE_T_MAX to <machine/rtems-bsd-user-space.h> | Sebastian Huber | |
2016-10-24 | Provide CLOCK_MONOTONIC_FAST | Sebastian Huber | |
2016-10-24 | Make <sys/proc.h> self-sufficient | Sebastian Huber | |
2016-10-24 | Make <machine/atomic.h> available to user space | Sebastian Huber | |
Enables use of <sys/refcount.h> in user space. | |||
2016-10-13 | Fix FreeBSD source file reverse conversion | Sebastian Huber | |
2016-10-13 | Remove AppleTalk support | Sebastian Huber | |
Prepare update to FreeBSD 11. | |||
2016-10-13 | pfctl: Update due to linker set API changes | Sebastian Huber | |
2016-10-07 | nexus-devices: Support arm/lpc24xx | Sebastian Huber | |
2016-10-07 | testsuite: Fix warnings | Sebastian Huber | |
2016-10-07 | ohci: Fixes due to USB stack update | Sebastian Huber | |
2016-09-28 | nexus-devices: Add arm/atsamv BSP section | Sebastian Huber | |
2016-09-28 | usb01: Simplify test program | Sebastian Huber | |
2016-09-28 | Split rtemsbsd/rtems/rtems-program.c | Sebastian Huber | |
This improves garbage collection by the linker. | |||
2016-09-28 | Split rtems-bsd-kernel-program.c | Sebastian Huber | |
Separate kernel and user space parts. | |||
2016-09-28 | Build rtems-bsd-shell-pfctl.c | Sebastian Huber | |
2016-09-28 | Split rtems-bsd-shell-netcmds.c | Sebastian Huber | |
