summaryrefslogtreecommitdiff
AgeCommit message (Collapse)Author
2020-03-18nfsclient: Use a system event for RPC5-freebsd-12Sebastian Huber
Aviod conflicts with application events.
2020-03-05waf: Change the test configure check for libdebugger to it's libChris Johns
- Add support for a 'test-if-library' - Use rtems_waf's 'test_application()' fragment in the check_cc call Closes #3948
2020-02-28rtems_waf: Update to master (096372fc4504)Chris Johns
Closes #3888
2020-02-27waf: Update to waf-2.0.19Sebastian Huber
Update #3569.
2020-02-18Update to FreeBSD stable/12 2020-02-10Sebastian Huber
Git mirror commit 0d1c391321b34b3025cf0e72f2231d836ff76da8.
2020-02-10epoch01: Update due to API changesSebastian Huber
Update #3815.
2020-02-10syscalls01: Fix sporadic test failuresSebastian Huber
2020-02-10EVENTHANDLER(9): Avoid multiple definition errorsSebastian Huber
2020-02-06dhcpcd: Pass config structure.Christian Mauderer
2019-12-19SOCKATMARK(3): Import from FreeBSDSebastian Huber
Close #3798.
2019-11-13NVMECONTROL(8): Port to RTEMSSebastian Huber
Update #3821.
2019-11-13NVMECONTROL(8): Add to buildSebastian Huber
Update #3821.
2019-11-13NVMECONTROL(8): Import from FreeBSDSebastian Huber
Update #3821.
2019-11-13NVD(4): Add RTEMS-specific NVMe disk driverSebastian Huber
Update #3821.
2019-11-13NVME(4): Add NVME_GET_NAMESPACE IO controlSebastian Huber
Update #3821.
2019-11-13NVME(4): Install header filesSebastian Huber
Update #3821.
2019-11-13NVME(4): Enable per-CPU IO queuesSebastian Huber
Update #3821.
2019-11-13NVME(4): Add support for SGLSebastian Huber
Update #3821.
2019-11-13NVME(4): Add SGL descriptorSebastian Huber
Update #3821.
2019-11-13NVME(4): Optimize data transferSebastian Huber
Update #3821.
2019-11-13NVME(4): Big endian supportSebastian Huber
Update #3821.
2019-11-13NVME(4): Port to RTEMSSebastian Huber
Update #3821.
2019-11-13NVME(4): Add build moduleSebastian Huber
Update #3821.
2019-11-13NVME(4): Import from FreeBSDSebastian Huber
Update #3821.
2019-09-25Add support for EARLY_COUNTERSebastian Huber
2019-09-25Fix warningsSebastian Huber
2019-09-25Remove obsolete header filesSebastian Huber
2019-09-25Compatibility for next Newlib updateSebastian Huber
2019-09-25Fix pgsigio() warningsSebastian Huber
2019-09-25Add compatiblity for older Newlib variantsSebastian Huber
2019-09-23Update to FreeBSD stable/12 2019-09-23Sebastian Huber
Git mirror commit 7e8d1444023128d34fb9aa4e4515928a4f794d1b.
2019-09-23Add pselect()Sebastian Huber
2019-09-23test/syscalls01: Fix sporadic test failuresSebastian Huber
2019-09-23PCI(4): Import missing fileSebastian Huber
2019-09-23PCI(4): Disable unsupported featuresSebastian Huber
2019-09-23PCI(4): Add big endian supportSebastian Huber
2019-09-23PCI(4): Install header filesSebastian Huber
2019-09-23Add <sys/disk.h> to build moduleSebastian Huber
2019-09-23CONFIG_INTRHOOK(9): Call handlers after bootSebastian Huber
This enables adding drivers on demand which use this service after initialization.
2019-09-23nexus: Avoid NULL pointer accessSebastian Huber
2019-09-23C++ compatibility for <dev/pci/pcivar.h>Sebastian Huber
2019-09-23C++ compatiblity for kernel space headerSebastian Huber
2019-09-23C++ compatibility for kernel space <sys/sysctl.h>Sebastian Huber
2019-09-11Add wrapper for strndup()Sebastian Huber
2019-08-27media01: Reduce record item countSebastian Huber
2019-08-27libsodium: Disable unused functionSebastian Huber
2019-08-27tty.c: Disable unused functionsSebastian Huber
2019-08-27pf_ioctl.c: Disable superfluous unload supportSebastian Huber
2019-08-27kern_intr.c: Disable unused functionsSebastian Huber
2019-08-27Remove superfluous support for preloaded modulesSebastian Huber
