This patch fixes a compiler warning:
../../../testsuites/fstests/fsdosfsname01/init.c:430:19: warning:
'%s' directive output may be truncated writing up to 6424 bytes into
a region of size 257 [-Wformat-truncation=]
The buffer 'dirname' is exactly large enough so that no truncation
can ever occur. Using the return value of snprintf() is an official
supported way to suppress the warning.
I considered the comment of Joel Sherrill about not replacing snprintf():
https://lists.rtems.org/pipermail/devel/2020-September/062113.html
When I use the 'shell' from the fileio sample with the command below:
env QEMU_AUDIO_DRV="none" \
qemu-system-arm -no-reboot -net none -nographic -M realview-pbx-a9 \
-m 256M \
-kernel build/arm/realview_pbx_a9_qemu/testsuites/samples/fileio.exe
The executable crashes with an "BLOWN STACK!!!" as soon as I try to login
as 'root' with password. (The logins without password work fine.)
Increasing the stack size of the affected thread a bit solves the issue.
Hence, I suggest this patch.
My config.ini was
[arm/realview_pbx_a9_qemu]
RTEMS_DEBUG = True
RTEMS_NETWORKING = True
RTEMS_POSIX_API = True
RTEMS_SMP = True
BUILD_TESTS = True
RTEMS origin.master at a479686c112144119866391ceb21c48be6a3eca9
Close #4143
This fixes the following compiler warning:
testsuites/psxtests/psxndbm01/init.c:221:3: warning: 'strncpy' output truncated
before terminating nul copying 5 bytes from a string of the same length
221 | strncpy( test_strings, "Hello", 5 );
In addition, the comments from Sebastian Huber on an old version of
such a patch have been taken into account:
1) The use of `sizeof()` in `key.dsize = sizeof( test_strings );` is wrong.
2) There is no need to allocate the string. One can simply use a string
constant.
(See https://lists.rtems.org/pipermail/devel/2020-August/061418.html)
Fix a compiler warning about a missing prototype.
If you wonder why the function name is not `static`:
The code in the file only serves a test where the dynamic object loader
(aka dlopen()) should handle duplicated symbols in an archive.
testsuites/libtests/dl10/dl10-o6.c:14:5: warning: no previous prototype
for 'rtems_main_o5' [-Wmissing-prototypes]
14 | int rtems_main_o5 (void)
Update #4105.
Fix spmsgq_err01 on systems with 64-bit pointers and correct max value
mismatches and inaccuracies that are more noticable on 64-bit systems.
Check the name followed by the id check in all create directives.
Compare pointers against NULL. Fix formatting.
Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of
test suites using the RTEMS Test Framework.
Update #4007.
In contrast to message queues created by rtems_message_queue_create(), the
message queues constructed by this directive use a user-provided message buffer
storage area.
Add RTEMS_MESSAGE_QUEUE_BUFFER() to define a message buffer type for message
buffer storage areas.
Update #4007.
Merge CORE_message_queue_Buffer structure into
CORE_message_queue_Buffer_control.
Use a zero-length array for the actual message buffer. This reduces the
structure size on all targets.
Update #4007.
Return a status code and differentiate between error conditions.
Update #4007.
This is the first test case generated from a specification item in the
rtems-central repository.
Update #3959.
Add a general purpose test suite for validation tests.
This is the first test suite generated from a specification item in the
Update #3959.
In contrast to rtems_task_create() this function constructs a task with
a user-provided task storage area. The new directive uses a
configuration structure instead of individual parameters.
Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a
task storage area based on the task attributes and the size dedicated to
the task stack and thread-local storage. This macro may allow future
extensions without breaking the API.
Add application configuration option
CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS
Workspace size estimate.
Update #3959.
Add this application configuration option. This configuration option can be
used to reserve space for the dynamic linking of modules with thread-local
storage objects.
Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a
thread-local storage size.
Update #4074.
Close #4034.
Update #3818.
Closes #4040.
On some simulators, a clock tick interval of 1ms seems to be too short.
For example, the test failed on sparc/erc32 using the SIS.
Hide implementation details.
Update #3959.
Simplify object name to identifier directives. Using
_RTEMS_Name_to_id() to implement the directives enables a tail call
optimization.
Change license to BSD-2-Clause according to file history.
Update #3053.
Key_ID array must have the right size, it shall have a value greater
than zero.
Note: In Standard C and C++, zero-size array is not
allowed..
Update #3199.
Normally, the expected test step must be a compile time constant. Allow
variable expected test steps for the T_step() and T_assert_step(). This
can be used for parameterized test loops with individual fixtures.
Remove the ability to use custom failure messages due to some
implementation constraints.
Update #3199.
Support a new test plan for each nested fixture.
Update #3199.
Return the produced character count. There is no need for a NUL
termination.
Update #3199.
Add support to record thread switch events. This can be used to check
that a blocking operation results in the expected sequence of thread
switches.
Update #3199.
Update #3199.
Since we need to test the strncpy function, using a character array with
a fixed array size in this case in place of character pointer can avoid
the string turncation warning.
Update #4032.
Update #4032.
This test support was replaced by T_interrupt_test() is no longer used.
