summaryrefslogtreecommitdiff
path: root/testsuites/fstests (unfollow)
AgeCommit message (Collapse)Author
2023-09-26tests: Add header for RTEMS test printerSebastian Huber
The <rtems/test-info.h> header file is required for every RTEMS test program. Move the RTEMS test printer support to a dedicated header file <rtems/test-printer.h>. This removes an unnecessary dependency to the RTEMS printer support in <rtems/test-info.h>. Tests using the RTEMS Testing Framework no longer depend on the <rtems/printer.h>.
2023-05-20Update company nameSebastian Huber
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
2023-03-15cpukit/jffs2: Add support for NAND under JFFS2Kinsey Moore
This adds write buffer and bad block support required for JFFS2 operation on NAND devices. This also adds the minor modifications necessary for RTEMS support in the Linux header stubs and in wbuf.c. Memory and NOR backed applications should experience no difference in operation since they do not expose the callbacks required for write buffer support.
2023-03-14doxygen: Add groups for related test suitesSebastian Huber
2022-08-05testsuite: Fix warningsChris Johns
Updates #4662
2022-06-21TFTPFS: Fix test configuration for FP targetsSebastian Huber
The test uses snprintf(). Update #4666.
2022-06-21TFTPFS: Reduce test configurationSebastian Huber
Update #4666.
2022-06-21TFTPFS: Add testsFrank Kühndel
Update #4666.
2022-04-12fstests/fsdosfsname01/create_image.sh: Manually change license to BSD-2Joel Sherrill
Updates #3053.
2022-04-12testsuites/fstests/*: Change license to BSD-2Joel Sherrill
Updates #3053.
2022-04-07testsuites/fstests/*: Change license to BSD-2Joel Sherrill
Updates #3053.
2022-03-10bsps/testsuites/: Scripted embedded brains header file clean upJoel Sherrill
Updates #4625.
2022-03-10testsuites/fstests/fsdosfsname01/create_files.cs: Convert to UNIX CR/LF.Joel Sherrill
This file had a mix of both DOS and UNIX CR/LF. Updates #4625.
2021-10-04testsuites/fstests: Fix uninitialized utimbuf structsAlex White
The utimbuf structs in fsimfsconfig01 and fsimfsconfig02 were being passed to utime uninitialized. This did not cause problems until utime was changed to use utimensat behind the scenes. Now that utimensat is called, the values of the utimbuf struct are checked, and EINVAL is set for invalid values. The utimebuf structs in these tests could contain invalid values since they are uninitialized. By zero-initializing the utimbuf structs, we ensure that they pass the checks in utimensat and that errno is set to the expected ENOTSUP.
2021-09-21build: Remove old build systemSebastian Huber
Close #3250. Close #4081.
2021-06-08fsnofs01/init.c: Check for ENOENT from utime().Joel Sherrill
The addition of the entire *utime*() family of functions resulted in this call returning ENOENT not ENXIO. This is better aligned with the POSIX definition of the methods.
2021-03-26libblock: Add rtems_bdbuf_peek()Christian Mauderer
Adds a peek function that allows (for example) a file system to suggest the next blocks that should be used for read ahead. This can increase the read speed of fragmented files. Update #3689
2020-10-15fsdosfsname01: Fix string truncation warningFrank Kühndel
This patch fixes a compiler warning: ../../../testsuites/fstests/fsdosfsname01/init.c:430:19: warning: '%s' directive output may be truncated writing up to 6424 bytes into a region of size 257 [-Wformat-truncation=] The buffer 'dirname' is exactly large enough so that no truncation can ever occur. Using the return value of snprintf() is an official supported way to suppress the warning. I considered the comment of Joel Sherrill about not replacing snprintf(): https://lists.rtems.org/pipermail/devel/2020-September/062113.html
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2020-03-13libio: Robust file descriptor reference countingSebastian Huber
There was a race conditon in the reference counting of file descriptors during a close() operation. After the call to the close handler, the rtems_libio_free() function cleared the flags to zero. However, at this point in time there may still exist some holders of the file descriptor. With RTEMS_DEBUG enabled this could lead to failed assertions in rtems_libio_iop_drop(). Change the code to use only atomic read-modify-write operations on the rtems_libio_iop::flags.
2020-03-04imfs: Add IMFS_add_node()Sebastian Huber
Update #3894.
2020-03-03fstests/fsrename: Rename a file twiceSebastian Huber
2020-02-25libio: Add POSIX user environment pointer to TCBSebastian Huber
The IO library used a POSIX key to store an optional POSIX user environment pointer. This pulled in the POSIX keys support in every application configuration. Add a user environment pointer to the thread control block (TCB) instead. Applications which do not need the POSIX user environment will just get an overhead of one pointer per thread. Close #3882.
2020-02-04fstests/fsstatvfs: Include missing header fileSebastian Huber
2019-12-19config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber
Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
2019-11-12fstests: Use tmacros.h instead of pmacros.hSebastian Huber
This avoids an extra include path. Update #3818.
2019-02-05fs: Add struct dirent::d_type supportSebastian Huber
2019-01-30build: Do not install test programsSebastian Huber
2019-01-07Fix format warningsSebastian Huber
2018-11-27dosfs: Fix device identifierSebastian Huber
Update #3358.
2018-10-12fsclose01: Fix uninitialized variable warningSebastian Huber
2018-10-10build: Remove local.amSebastian Huber
2018-10-10build: Directly reference libraries in testsSebastian Huber
Remove use of TMPINSTALL_FILES.
2018-08-15fsdosfssync01/init.c: Remove unused variableJoel Sherrill
2018-08-07tests: Avoid deprecated rtems_disk_io_initialize()Sebastian Huber
Update #3358.
2018-08-07ramdisk: Use rtems_blkdev_create()Sebastian Huber
Update #3358.
2018-06-14tools: Remove rtems-bin2cSebastian Huber
This tool is now included in the RTEMS tools repository. Close #3380.
2018-05-02tests: Remove configure feature checksSebastian Huber
Update #3409.
2018-04-30Drop executable permissions on .[ch] filesJoel Sherrill
2018-04-11configure: Add subdir-objects to all automake flags.Chris Johns
This option silences warning with automake-1.16.1 allowing us to upgrade to that version. This change has been tested with automake-1.12.6 and automake-1.16.1. It seems version 1.16.1 configures slower than 1.12.6 for the same source and BSP. The newer versions is 6 second slower. Close #3387.
2018-04-11fstest/fsrfsbitmap01: Update RFS bitmap tests to test fixes.Chris Johns
Add tests to check the patches for this ticket exist and are fixed. Close #3089
2018-04-10testsuite/fstests: Merged nested Makefile.am files into one Makefile.amChris Johns
This change is part of the testsuite Makefile.am reorganization. Update #3382
2018-04-04build: Remove EXTRA_DISTSebastian Huber
A "make dist" is not supported. So, it makes no sense to have pure "make dist" related stuff in the Makefile.am.
2018-02-09fsclose01: Fix task mode, use attributeSebastian Huber
Update #1971.
2018-02-09fsclose01: Use floating-point taskSebastian Huber
The tmpfile() uses sprintf(). Update #1971.
2018-02-05fsclose01: Add tmpfile() test caseSebastian Huber
Close #1971.
2018-01-25Remove make preinstallChris Johns
2018-01-19fstests: Use floating-point taskSebastian Huber
The fstests use snprintf().
2017-12-07dosfs: Allow creating a file with similar name.Christian Mauderer
If there is already a file with a long file name it isn't possible to create a second file which has a name that ends on the first files name (for example ets.beam and sets.beam). This patch fixes that. Update #3258.
