Update #3910.
This fixes warnings like this:
warning: implicit declaration of function 'rtems_interrupt_disable'
warning: implicit declaration of function 'rtems_interrupt_enable'
warning: implicit declaration of function 'rtems_interrupt_flash'
Close #4140.
Update #3818.
This adds an AArch64 ILP32 BSP variant based on Qemu's Cortex-A53
emulation with interrupt support using GICv3 and clock support using
the ARM GPT.
This adds an AArch64 basic BSP based on Qemu's Cortex-A53 emulation with
interrupt support using GICv3 and clock support using the ARM GPT.
This breaks out AArch32-specific code so that the shared GICv3 code can
be reused by other architectures.
This breaks AArch32-specific portions of the ARM GPT driver into their
own file so that the generic code can be moved for reuse by other
architectures.
This UART driver is now needed for BSPs other than ARM.
Close #4121.
Update #3818.
Do not force BSPs to define __ppc_generic.
This was probably the last command line define in the BSPs.
commit 20c89ab7c5091ee48535392cae2177aa1a1c43eb
Author: Segher Boessenkool <segher@kernel.crashing.org>
Date: Fri Jan 12 21:50:52 2018 +0100
rs6000: Remove -mstring
-mstring is only enabled by default on 601, and with -Os on some
configurations. It is almost always slower (than not using it) and
does not very often lead to smaller code.
This patch disables it. If a user uses -mstring he gets a warning
(but not with -mno-string). I left the target attribute in place, it
just doesn't do anything anymore.
The patch also deletes a whole bunch of code. The 'N' and 'O' output
modifiers are now unused, but now is not the time to delete them.
Remove -fno-common because it is the default since GCC 10.
Use -B for the linker since some architectures use extra start files defined by
the GCC specification and provided by the BSP, for example powerpc. Start
files are not found by -L.
In the long run, the GCC defined start files should be provided by GCC. This
is a GCC 11 topic.
Update #3818
Add a general purpose test suite for validation tests.
This is the first test suite generated from a specification item in the
rtems-central repository.
Update #3959.
Update #3818.
Make the objcopy an bld.objects() task generator.
Close #4079.
Update #3818.
Update #3818.
Update #3818.
Update #3818.
Update #3818.
