2019-07-19 | Makefile.inc: Add support for staged builds. | Chris Johns | |
- Allow the RTEMS_ROOT to be conditionally supplied. This can be a staging area before being moved to the final install prefix location. - Update the default.cfg to use RTEMS_ROOT and to not rely on the exec_prefix so it's paths can be staged. - Fix and add the needed configure subs. Closes #3768 | |||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | |
2011-04-01 | 2011-04-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* custom/default.cfg: Update to account for movement of .cfg files. | |||
2009-10-16 | Remove (Abandoned). | Ralf Corsepius | |
2009-10-15 | Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | Ralf Corsepius | |
2009-10-15 | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* custom/lm32_evr.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | |||
* custom/brs5l.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | |||
* custom/h8sim.cfg, custom/h8sxsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | |||
* custom/c3xsim.cfg, custom/c4xsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | |||
* custom/nios2_iss.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | |||
2009-10-14 | Remove. | Ralf Corsepius | |
2009-10-05 | add missing files | Thomas Doerfler | |
2009-10-05 | renamed config files | Thomas Doerfler | |
2009-10-01 | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile.am: Add new BSP variants for ARM simulator in GDB. * custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg, custom/armcortexa9.cfg: New files. | |||
2009-09-24 | 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile.am: Add qemuppc.cfg. * custom/qemuppc.cfg: New file. | |||
2009-09-14 | 2009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* custom/gen83xx.cfg: Remove -funit-at-a-time. | |||
2009-08-27 | 2009-08-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* custom/leon2.cfg, custom/leon3.cfg: Fix typo. | |||
2009-06-04 | 2009-06-04 Xi Yang <hiyangxi@gmail.com> | Joel Sherrill | |
* Makefile.am: New Gumstix BSP. * custom/gumstix.cfg: New file. | |||
2009-05-28 | 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* custom/csb637.cfg: New file. | |||
2009-02-27 | added missing files | Thomas Doerfler | |
2009-02-27 | * README: Added NCS. | Thomas Doerfler | |
* Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot. | |||
2009-02-19 | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* custom/simsh2e.cfg: New file. | |||
2009-02-17 | 2009-02-17 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | |
PR 1371/bsps * custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF. | |||
2009-02-17 | 2009-02-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* custom/uC5282.cfg: Add cvs Id. | |||
2009-02-11 | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* custom/h8sxsim.cfg: Small H8SX should be optimized for size. | |||
2009-02-06 | Remove. | Ralf Corsepius | |
2009-02-05 | 2009-02-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* custom/pck6.cfg: Remove. | |||
2008-12-04 | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | |
* Makefile.am: Add Lattice Mico32 support. * custom/lm32_evr.cfg: New file. | |||
2008-11-20 | 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* custom/avrtest.cfg: New file. | |||
2008-11-20 | 2008-11-20 Daron Chabot <daronchabot@gmail.com> | Joel Sherrill | |
PR 1337/bsps * custom/pc386.cfg: Stripping .rodata section produces unusable executables for the i386-rtems target. | |||
2008-10-14 | 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile.am: Add h8sxsim BSP variant. * custom/h8sxsim.cfg: New file. | |||
2008-10-10 | Added -msoft-float and removed -funit-at-a-time in CPU_CFLAGS | Thomas Doerfler | |
2008-10-02 | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* custom/m32rsim.cfg: New file. | |||
* custom/m32csim.cfg: New file. | |||
2008-10-02 | Remove -Dvirtex. | Ralf Corsepius | |
2008-10-02 | Remove RTEMS_TQM_MODEL. | Ralf Corsepius | |
2008-10-02 | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | |
2008-10-02 | Remove RTEMS_BOARD_MODEL. Remove RTEMS_54XX_DERIVATE (Unused). | Ralf Corsepius | |
