#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Close #3543.
Update #3543.
Update #3543.
Update #3543.
Update #3543.
Use the minimum task size for the telnet server task since it has to
deal only with simple socket operations.
Update #3543.
The Telnet service started via rtems_telnetd_start() had a keep stdio
feature. This just created a task and executed the command function in
a loop. For this kind of service we do not library support. This can
be done by an application task on its own. Remove this feature and
provide only the real Telnet server functionality.
Use syslog() for error and status messages.
Add test program for the Telnet server.
Close #3542.
Update #3529.
Update #3530.
Update #3533.
Close #3535.
Add a rtems_telnetd_config_table::client_maximum member to the Telnet
configuration.
Close #3526.
Close #3528.
Update #3528.
Update #3526.
cpukit/telnetd/pty.c:436:47: warning: '%X' directive writing between
1 and 8 bytes into a region of size 3 [-Wformat-overflow=]
The devname area was malloc'ed. Now it is statically allocated and
sufficiently large to account for the potential buffer overflow.
Update #3419.
Add support for libbsd initialization.
Update #3419.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Prepare for header file move to common include directory.
Update #3254.
not updated.
It is not so easy to use Termios for that. We already map CRNUL to CR,
thus we cannot ignore CRs. We could change the shell code to map CRNL
to a single line end, but this is more intrusive than the change here.
The standard line editor rtems_shell_line_editor() produces an echo.
for details.
PR 1985/cpukit
* telnetd/Makefile.am: Remove icmds.c.
PR 1985/cpukit
* telnetd/icmds.c: Removed.
All functionality is in shell. Obsolete and unreferenced.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* libgnat/ada_intrsupp.c, telnetd/check_passwd.c, telnetd/des.c,
telnetd/genpw.c: Add include of config.h
* telnetd/telnetd.c: Honor configuration setting for telnet daemon
stack size.
* telnetd/pty.c:
Reflect changes to rtems_termios_callbacks->write.
* telnetd/telnetd.c (telnetd_dflt_spawn): Adjust prototype.
* telnetd/des.c: Split the des_f struct into smaller parts so
targets that cannot address large structs can be supported.
* libmisc/uuid/gen_uuid.c, libnetworking/lib/syslog.c,
telnetd/telnetd.c: Fixed warnings.
* telnetd/telnetd.h: Spacing.
* Makefile.am, preinstall.am, libmisc/Makefile.am,
libmisc/shell/shell.c, libmisc/shell/shell.h, telnetd/check_passwd.c,
telnetd/telnetd.c, telnetd/telnetd.h:
Generalized login check.
* libmisc/shell/login.h, libmisc/shell/login_check.c,
libmisc/shell/login_prompt.c: New files.
* libmisc/stackchk/check.c: Changed format for blown stack message.
* libcsupport/src/libio_sockets.c: Removed superfluous cast.
* libnetworking/rtems/ftpfs.h: Documentation.
PR 1331/networking
* libmisc/shell/shell.c, telnetd/check_passwd.c, telnetd/telnetd.c,
telnetd/telnetd.h: Improve comments and explanation of options to
rtems_telnetd_initialize. Add extra newline to login sequence from
shell.
