summaryrefslogtreecommitdiff
path: root/cpukit/score/cpu/nios2/include/rtems/asm.h (follow)
AgeCommit message (Collapse)Author
2019-04-01doxygen: score: Add nios2 CPU architecture groupAndreas Dachsberger
Update #3706.
2018-01-25Remove make preinstallChris Johns
