2020-07-23 | libtest: Add T_CHECK_FMT | Sebastian Huber | |
Rename internal function T_check_true() to T_check() and use the new flag T_CHECK_FMT to indicate if a format string is present. This is a preparation step to make the format string optional. Make the check context the first parameter. The API remains the same. Update #3199. | |||
2020-07-23 | libtest: Move <t.h> to <rtems/test.h> | Sebastian Huber | |
Update #3199. | |||
2019-03-27 | Add RTEMS Test Framework | Sebastian Huber | |
Update #3199. |
