2017-08-22 | heap: Fix integer types | Sebastian Huber | |
Update #3082. | |||
2017-05-02 | shell: Fix format specifiers | Sebastian Huber | |
2015-01-22 | score: Delete superfluous Heap_Statistics::instance | Sebastian Huber | |
This value depends on the _Heap_Initialize() call sequence and carries no useful information. | |||
2014-11-28 | score: Add heap statistics | Sebastian Huber | |
Add lifetime bytes allocated and freed since they were present in the malloc statistics. Add number of failed allocations. | |||
2014-11-28 | score: Return heap stats via _Heap_Get_information | Sebastian Huber | |
Print out heap statistics via the MALLOC and WKSPACE shell commands. | |||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2008-03-05 | 2008-03-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* libmisc/Makefile.am, libmisc/shell/main_cp.c, libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c, libmisc/shell/main_mallocinfo.c, libmisc/shell/main_netstats.c, libmisc/shell/main_perioduse.c, libmisc/shell/main_stackuse.c, libmisc/shell/main_wkspaceinfo.c, libmisc/shell/print_heapinfo.c, libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/shell/shell_makeargs.c, libmisc/shell/shellconfig.c, libmisc/shell/shellconfig.h, libmisc/shell/write_file.c: Add initial capability to automatically execute a script from the filesystem. Add echo command from NetBSD and sleep command. * libmisc/shell/main_echo.c, libmisc/shell/main_sleep.c, libmisc/shell/shell_script.c: New files. | |||
2008-01-07 | 2008-01-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* libmisc/Makefile.am: Add new files. * libmisc/shell/internal.h: Prototype for rtems_shell_print_heap_info() * libmisc/shell/main_mallocinfo.c: Use rtems_shell_print_heap_info(). * libmisc/shell/shellconfig.h: Add wkspace command. * libmisc/shell/main_wkspaceinfo.c, libmisc/shell/print_heapinfo.c: New files. |
