summaryrefslogtreecommitdiff
path: root/cpukit/libmisc/redirector (follow)
AgeCommit message (Collapse)Author
2018-10-02Use rtems_task_exit()Sebastian Huber
Update #3530. Update #3533.
2018-02-07stdio-redirector: Use self-contained mutexSebastian Huber
Update #2843.
2018-01-25Remove make preinstallChris Johns
2017-12-13redirector: Include <rtems/stdio-redirect.h>Sebastian Huber
Prepare for header file move to common include directory. Update #3254.
2017-08-25Include missing <string.h>Sebastian Huber
Update #2133.
2015-03-18libmisc/redirector: Fix unlock on exit from the handler.Chris Johns
2014-10-16libmisc/redirector/stdio-redirect.c: Use UL constants since usleep() should ↵Joel Sherrill
take more than 16-bit constants
2014-10-13libmisc/redirector/stdio-redirect.c: Use sleep not usleep and do not ↵Joel Sherrill
overflow 16-bit int
2014-09-17redirector: Rename rtems_stdio_redirect_tSebastian Huber
Rename rtems_stdio_redirect_t to rtems_stdio_redirect since the namespace *_t is reserved by POSIX, see also The Open Group Base Specifications Issue 6 IEEE Std 1003.1, 2004 Edition, 2.2.2 The Name Space.
2014-09-16libmisc: Add a stdio redirector helper.Chris Johns
This module makes it easy to redirect and capture stdout, stderr or any other fd in your application. The captured data can be sent off board, for example using syslog, or buffered and displayed in a web page.
