summaryrefslogtreecommitdiff
path: root/cpukit/libmisc/fb (follow)
AgeCommit message (Collapse)Author
2020-04-28doxygen: Switch @brief and @ingroupSebastian Huber
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2018-01-25Remove make preinstallChris Johns
2016-06-22Move printer initialization to separate headerSebastian Huber
The RTEMS print user need to know nothing about a particular printer implementation. In particular get rid of the <stdio.h> include which would be visible via <rtems.h>.
2016-05-25cpukit, testsuite: Add rtems_printf and rtems_printer support.Chris Johns
This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work.
2015-10-26basdefs.h: Add and use RTEMS_UNUSEDSebastian Huber
2015-03-11cpukit: Remove old DESCRIPTION: in commentsJoel Sherrill
These were remnants of pre-Doxygen comment style.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns
2014-01-09mw_uid: corrects uid_read_message short timeoutsAllan Hessenflow
2013-01-10cpukit: Doxygen group fixes and many warnings addressedJoel Sherrill
The output of the modules.html is much improved. Most filesystem and POSIX API related groups are properly nested. Some formatting issues were addressed as were multiple inconsistencies.
2013-01-04libmisc: Doxygen Clean Up Task #1Ayush Awasthi
Conflicts occured durning this patch and modifications in the repo were favored over the patch.
2012-12-28Header File Doxygen Enhancement Task #2Mathew Kallada
2012-12-21libmisc: Doxygen Enhancement Task #1Mathew Kallada
2012-10-19Make uid_buttons static.Ralf Corsépius
Reorder include-files. Remove stray blanks.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-07-112011-07-11 Sebastien Bourdeauducq <sebastien.bourdeauducq@gmail.com>Sebastian Huber
PR 1823/cpukit * libmisc/fb/fb.h: Added FBIOSETVIDEOMODE define.
2011-06-242011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen.
2011-02-172011-02-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* libmisc/Makefile.am, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: Clean up. Add Doxygen style comments. Add method to print uid structure. * libmisc/fb/mw_print.c: New file.
2010-08-202010-08-20 <yann.sionneau@telecom-sudparis.eu>Joel Sherrill
* libmisc/fb/fb.h: Add constants for buffer modes.
2009-11-29Whitespace removal.Ralf Corsepius
2009-08-212009-08-21 Roxana Leontie <roxana.leontie@gmail.com>Joel Sherrill
* Makefile.am, preinstall.am, libmisc/Makefile.am: Changed the name of mw-fb directory into fb. Relocated files. * libmisc/fb/fb.h, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: New files. * libmisc/mw-fb/fb.h, libmisc/mw-fb/mw_uid.c, libmisc/mw-fb/mw_uid.h: Removed.
