summaryrefslogtreecommitdiff
path: root/cpukit/libfs/src (follow)
AgeCommit message (Collapse)Author
2020-10-17libfs/rfs: Check search bit map end on last bitChris Johns
- Do not write past the last location of the search bit map whe nit is being created. Closes #4148
2020-08-04dosfs: Fix memory leak on failed mounts.Christian Mauderer
Currently if mount fails, a converter isn't destroyed. We have to take care of two cases: 1. The user doesn't provide a converter. In this case mounting a dosfs creates a default converter. This patch makes sure that the converter is destroyed again if mount failes for this case. 2. The user provides a converter. In this case it's not sure that the dosfs specific routines are reached because mount can fail before that. Therefore the user has to destroy the converter himself again. This patch adds a documentation for that and implements it in the media server. Closes #4042.
2020-07-14rtems: Remove deprecated rtems_io_lookup_name()Sebastian Huber
Close #3420.
2020-04-28doxygen: Switch @brief and @ingroupSebastian Huber
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2020-03-09imfs: Replace devfs with an IMFS specializationSebastian Huber
Add a simplified path evaluation function IMFS_eval_path_devfs() for a device only IMFS configuration. The code size can be further reduced by the application if it disables the support for legacy IO drivers via: #define CONFIGURE_IMFS_DISABLE_MKNOD #define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES. Update #3894. Update #3898.
2020-03-09imfs: Simplify code generationSebastian Huber
Update #3894.
2020-03-09imfs: Remove unused handlersSebastian Huber
Update #3894.
2020-03-09imfs: Constify imfs_memfile_bytes_per_blockSebastian Huber
The CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK value is validated by <rtems/confdefs/libio.h>. Changing this value during runtime could lead to memory corruption. Update #3894.
2020-03-09imfs: Use _IMFS_get_time()Sebastian Huber
Update #3894.
2020-03-04imfs: Add IMFS_add_node()Sebastian Huber
Update #3894.
2020-03-04imfs: Simplify IMFS_create_node()Sebastian Huber
Update #3894.
2020-03-04imfs: Remove IMFS_NODE_FLAG_NAME_ALLOCATEDSebastian Huber
Remove IMFS_NODE_FLAG_NAME_ALLOCATED and instead replace the node control in rename operations. This avoids a special case in the general node destruction which pulled in free(). Update #3894.
2020-01-03cpukit/libfs: remove more dead code from pipe/fifo.cGedare Bloom
Dead code identified by Coverity (CID 1456674). The value of ret at line 358 is always 0.
2020-01-03cpukit/libfs: remove dead code from pipe/fifo.cGedare Bloom
Dead code identified by Coverity (CID 1456678). The value of ret at line 293 is always 0.
2019-12-11pipe: Use condition variablesSebastian Huber
Use self-contained condition variables instead of Classic API barriers. This simplifies the implementation and configuration. Update #3840.
2019-11-25untar: Unify untar supportSebastian Huber
Update #3823.
2019-11-21imfs: Fix IMFS_make_linearfile()Sebastian Huber
Fix prototype. Fix node size. Linfiles are dynamically turned into memfiles. Update #3823.
2019-11-19imfs: Add IMFS_make_linfile()Sebastian Huber
Update #3818.
2019-10-01dosfs: Fix format with media block sizes > 512Sebastian Huber
2019-04-02doxygen: Added groups to IO libraryAndreas Dachsberger
Update #3706.
2019-03-25libfs/src/pipe/fifo.c: Fix warning.Joel Sherrill
2019-03-14fifo.c: Eliminate logically dead code (Coverity 1437635)Joel Sherrill
2019-02-28Remove explicit file names from @fileSebastian Huber
This makes the @file documentation independent of the actual file name. Update #3707.
2019-02-05fs: Add struct dirent::d_type supportSebastian Huber
2019-01-10Fix format warnings due to ino_t changesSebastian Huber
2018-12-04Spelling and grammar fixes in source code comments (GCI 2018)Marçal Comajoan Cara
2018-12-025 spelling errors for a Google Code-In task.Jacob Shin
Username: deuteriumoxide Email: jacobshin313@gmail.com
2018-11-27dosfs: Fix device identifierSebastian Huber
Update #3358.
2018-11-22pipe/fifo.c: Remove dead code (CID 1437649)Joel Sherrill
Closes #3581.
2018-10-10build: Merge libfs/Makefile.amSebastian Huber
2018-10-05jffs2: Avoid use of constant register variableSebastian Huber
Avoid the use of a constant register variable which is used in some conditions. This gets rid of a clang -Wsometimes-uninitialized warning.
2018-10-04Remove superfluous pipe_create()Sebastian Huber
2018-10-02Use rtems_task_exit()Sebastian Huber
Update #3530. Update #3533.
2018-09-10network: Use kernel/user space header filesSebastian Huber
Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375.
2018-09-07nfsclient: Fix unused variable warningSebastian Huber
2018-08-07dosfs: Avoid deprecated routineSebastian Huber
Update #3358.
2018-08-07rfs: Remove erroneous call of rtems_disk_release()Sebastian Huber
The function rtems_rfs_buffer_sync() erroneously calls rtems_disk_release(). This screws up the reference counting of the disk. Close #3484.
2018-07-19jffs2: Rename README to VERSIONSebastian Huber
This makes it easer to find files describing an upstream version, e.g. via "find -name VERSION". Update #3465.
2018-07-16jffs2: Add READMESebastian Huber
Add README to document the corrspending Linux version and the update procedure. Close #3465.
2018-07-16mtd: Unconditionally update ->fail_addr and ->addr in part_erase()Boris Brezillon
->fail_addr and ->addr can be updated no matter the result of parent->_erase(), we just need to remove the code doing the same thing in mtd_erase_callback() to avoid adjusting those fields twice. Note that this can be done because all MTD users have been converted to not pass an erase_info->callback() and are thus only taking the ->addr_fail and ->addr fields into account after part_erase() has returned. While we're at it, get rid of the erase_info->mtd field which was only needed to let mtd_erase_callback() get the partition device back. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Richard Weinberger <richard@nod.at>
2018-07-16mtd: Stop assuming mtd_erase() is asynchronousBoris Brezillon
None of the mtd->_erase() implementations work in an asynchronous manner, so let's simplify MTD users that call mtd_erase(). All they need to do is check the value returned by mtd_erase() and assume that != 0 means failure. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Richard Weinberger <richard@nod.at>
2018-07-16jffs2: fix spelling mistake: "requestied" -> "requested"Colin Ian King
trivial fix to spelling mistake in JFFS2_ERROR message Signed-off-by: Colin Ian King <colin.king@canonical.com> [Brian: also fix 'an' -> 'a'] Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2018-07-16sched/headers: Prepare to move signal wakeup & sigpending methods from ↵Ingo Molnar
<linux/sched.h> into <linux/sched/signal.h> Fix up affected files that include this signal functionality via sched.h. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2018-07-16jffs2: Remove jffs2_{get,set,remove}xattr macrosAndreas Gruenbacher
When CONFIG_JFFS2_FS_XATTR is off, jffs2_xattr_handlers is defined as NULL. With sb->s_xattr == NULL, the generic_{get,set,remove}xattr functions produce the same result as setting the {get,set,remove}xattr inode operations to NULL, so there is no need for these macros. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-07-16vfs: make the string hashes salt the hashLinus Torvalds
We always mixed in the parent pointer into the dentry name hash, but we did it late at lookup time. It turns out that we can simplify that lookup-time action by salting the hash with the parent pointer early instead of late. A few other users of our string hashes also wanted to mix in their own pointers into the hash, and those are updated to use the same mechanism. Hash users that don't have any particular initial salt can just use the NULL pointer as a no-salt. Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: George Spelvin <linux@sciencehorizons.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-07-16mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-07-16jffs2: Improve post-mount CRC scan efficiencyDavid Woodhouse
We need to finish doing the CRC checks before we can allow writes to happen, and we currently process the inodes in order. This means a call to jffs2_get_ino_cache() for each possible inode# up to c->highest_ino. There may be a lot of lookups which fail, if the inode# space is used sparsely. And the inode# space is *often* used sparsely, if a file system contains a lot of stuff that was put there in the original image, followed by lots of creation and deletion of new files. Instead of processing them numerically with a lookup each time, just walk the hash buckets instead. [fix locking typo reported by Dan Carpenter] Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2018-07-16Fix directory hardlinks from deleted directoriesDavid Woodhouse
When a directory is deleted, we don't take too much care about killing off all the dirents that belong to it — on the basis that on remount, the scan will conclude that the directory is dead anyway. This doesn't work though, when the deleted directory contained a child directory which was moved *out*. In the early stages of the fs build we can then end up with an apparent hard link, with the child directory appearing both in its true location, and as a child of the original directory which are this stage of the mount process we don't *yet* know is defunct. To resolve this, take out the early special-casing of the "directories shall not have hard links" rule in jffs2_build_inode_pass1(), and let the normal nlink processing happen for directories as well as other inodes. Then later in the build process we can set ic->pino_nlink to the parent inode#, as is required for directories during normal operaton, instead of the nlink. And complain only *then* about hard links which are still in evidence even after killing off all the unreachable paths. Reported-by: Liu Song <liu.song11@zte.com.cn> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: stable@vger.kernel.org
2018-07-16jffs2: Fix page lock / f->sem deadlockDavid Woodhouse
With this fix, all code paths should now be obtaining the page lock before f->sem. Reported-by: Szabó Tamás <sztomi89@gmail.com> Tested-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: stable@vger.kernel.org
