2018-04-20 | drvmgr: Remove bsp_driver_level_hook() | Sebastian Huber | |
Use RTEMS_SYSINIT_ITEM() instead. Update #2408. | |||
2017-12-06 | drvmgr: Use API mutex | Sebastian Huber | |
2017-03-06 | libdrvmgr: added default BSP init level hook | Daniel Hellstrom | |
2016-02-03 | Use linker set for driver manager initialization | Sebastian Huber | |
Update #2408. | |||
2016-01-26 | Revert "drvmgr: Move bsp_driver_level_hook() calls" | Sebastian Huber | |
The --enable-drvmgr configure option controls the driver manager startup and not if the driver manager is present or not. Presence of the driver manager is determined by the architecture (only available on sparc so far). This reverts commit 61bbf9194ff4bdbc1b48e6ac9919c02b358e5701. | |||
2016-01-26 | drvmgr: Move bsp_driver_level_hook() calls | Sebastian Huber | |
2015-04-17 | DRVMGR: remove struct driver registration func | Daniel Hellstrom | |
2015-04-17 | DRVMGR: renamed private drv_mgr and its struct name | Daniel Hellstrom | |
2015-04-17 | DRVMGR: updated license to rtems.org | Daniel Hellstrom | |
2015-04-17 | DRVMGR: removed a goto and added comments | Daniel Hellstrom | |
2015-04-17 | DRVMGR: updated copyright into one line only | Daniel Hellstrom | |
2015-04-17 | DRVMGR: added driver manager to cpukit/libdrvmgr | Daniel Hellstrom | |
