The argument to the ctype functions must be an int and the value of the
character must be representable as an unsigned char or equal to the
value of the macro EOF. If the argument has any other value, the
behavior is undefined.
Use with the trace outout to check for allocation leaks.
- The change from bool to an enum did not trip a compiler warning
and only the rel path was changed. The rela path was missed so
archs like SPARC failed.
Updates #3969
Updates #3969
- The check was for greater than and not equal or greater
Updates #3969
Updates #3969
Updates #3969
Updates #3969
This patch is an updated version from:
https://lists.rtems.org/pipermail/users/2016-January/029740.html
Closes #3693
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Support for targets compiled with -fno-pic and -mno-relax
Closes #3777
Closes #3776
- No need to dump globals syms in test dl01 when tracing
Closes #3775
- Replace the linear object file symbol search with a binary search.
- Sort the object file symbols after loading.
Closes #3748
This was introduced in 74883be5d4b5fa166179d6003032f6eac2e0f544.
Updates #3746
- Make the symbol parsing and loading stage match.
- Check for possible overflow of the tables when loading.
Closes #3746
- Load symbols before allocation.
- Parse reloc records and place any reloc recs in a cache to use
while the allocator is locked.
- Relocate symbols after section allocation.
- Split section loading into allocation/locating and loading.
- Update all arch back-ends with a new reloc interface to control
tramp handling.
- Add `-a` and `-t` to the object list shell command.
Closes #3741
- The archive command lists archives, symbols and any duplicate
symbols.
- Change the RTL shell commands to the rtems_printer to allow
the output to be captured.
Updates #3687
Coverity 1399717
Updates #3686
Coverty 1442636
Updates #3686
space.
Coverity issue 1442540
Updates #3686
Coverity issue 1442641
Updates #3686
- Allow an allocator to lock the allocations. This is needed to
lock the heap allocator so the text and trampoline table are
as close together as possible to allow for the largest possible
object file size.
- Update the default heap allocator to lock the heap allocator.
- Update ELF loading to lock the allocator.
Updates #3685
Updates #3687
Close #3692
- Add support for architecure sections that can be handled by the
architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
makes the linker allocated small data region of memory a global
resource available to libdl loaded object files.
Updates #3687
Updates #3685
- Add trampolines to support relocs that are out of range on
support architectures.
- Support not loading separate text/data sections in an object
file if the symbol provided in the section is a duplicate.
A base image may have pulled in part of an object and another
part needs to be dynamically loaded.
- Refactor the unresolved handling to scale to hundreds of
unresolved symbols when loading large number of files.
Updates #3685
- Trampolines or fixups for veneers provide long jump support
for instruciton sets that implement short relative address
branches. The linker provides trampolines when creating a
static image. This patch adds trampoline support to libdl
and the ARM architecture.
- The dl09 test requires enough memory so modules are outside
the relative branch instruction ranges for the architecture.
Updates #3685
- Fix the handling of pending objects.
- Add a constructor flags in objects to track then being called.
Closes #2921
- Load archive symbol tables to support searching of archives
for symbols.
- Search archive symbols and load the object file that contains
the symbol.
- Search the global and archives until all remaining unresolved symbols
are not found. Group the loaded object files in the pending queue.
- Run the object file and loaded dependents as a group before adding to the
main object list.
- Remove orphaned object files after references are removed.
Updates #3686
Closes #3298
Username: deuteriumoxide Email: jacobshin313@gmail.com
Tracking references lets us manage when an object file can be
unloaded. If an object file has references to it, it cannot be
unloaded.
Modules that depend on each other cannot be unloaded.
Updates #3605
Updates #3194
The use of separate text and data results in uninitialised variables
being placed in the common section. There is no section in ELF for
the common variables so the loader needs to create the section and
allocate the variables in that section. This patch does that.
The patch adds a second pass over the symbols.
The issue can also be seen as a section 65522 error.
Updates #3604
Update #3375.
- Do not error if a RAP section is not found.
- Free a symbol table via the RTL allocator interface.
- Add the symbols to the global symbol table.
Update #2769
Update #2843.
Update #2843.
Update #2843.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Prepare for header file move to common include directory.
Update #3254.
Update #3155.
Update #3155.
