summaryrefslogtreecommitdiff
path: root/cpukit/include/rtems/init.h (follow)
AgeCommit message (Collapse)Author
2020-10-10rtems: Improve RTEMS_NO_RETURN attributeSebastian Huber
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors like this: error: no return statement in function returning non-void [-Werror=return-type] Use C11 and C++11 standard means to declare a no-return function. Close #4122.
2018-11-08rtems: Move includes out of extern "C" scopeSebastian Huber
2018-01-25Remove make preinstallChris Johns
