2020-04-16 | Canonicalize config.h include | Sebastian Huber | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||
2020-03-31 | ftpd: Fix return types | Sebastian Huber | |
2018-11-20 | Misc: Minor English fixes (GCI 2018) | kuaLeYi | |
2018-10-30 | ftpd: Avoid TOCTOU problem | Sebastian Huber | |
Assume that opendir() returns only non-NULL if we actually open a directory. Update #3530. | |||
2018-10-30 | ftpd: Deal with too long command lines | Sebastian Huber | |
Update #3530. | |||
2018-10-30 | ftpd: Make send_dirline() more robust | Sebastian Huber | |
Account for large file names. Update #3530. | |||
2018-10-09 | build: Merge ftpd/Makefile.am | Sebastian Huber | |
2018-10-09 | ftpd: Restructure chroot() handling. | Sebastian Huber | |
Remove superfluous setting of errno = 0. Update #3530. | |||
2018-10-08 | ftpd: Remove superfluous temporary buffer | Sebastian Huber | |
Update #3530. | |||
2018-10-08 | ftpd: Check return status of getsockname() | Sebastian Huber | |
Update #3530. | |||
2018-10-05 | ftpd: Fix insecure chroot() handling | Sebastian Huber | |
Ensure that the rtems_libio_set_private_env() was successful before the chroot(). Update #3530. | |||
2018-10-05 | ftpd: Avoid resource leak | Sebastian Huber | |
Update #3530. | |||
2018-10-05 | ftpd: Avoid use of uninitialized memory | Sebastian Huber | |
Update #3530. | |||
2018-10-05 | ftpd: Avoid malloc() and sscanf() | Sebastian Huber | |
Move the user name to the session information. Update #3530. | |||
2018-10-05 | ftpd: Remove FTPD_SessionInfo_t::pass member | Sebastian Huber | |
There is no need to keep the password throughout the session. Update #3530. | |||
2018-10-05 | ftpd: Avoid NULL pointer checks before free() | Sebastian Huber | |
They are superfluous and just bloat the code. Update #3530. | |||
2018-10-02 | Use rtems_task_exit() | Sebastian Huber | |
Update #3530. Update #3533. | |||
2018-05-08 | ftpd: Fix infinite recursion in yield() | Sebastian Huber | |
Update #3419. | |||
2018-05-02 | ftpd: Always build FTP daemon | Sebastian Huber | |
Add support for libbsd initialization. Update #3419. | |||
2018-05-02 | ftpd: Use floating-point tasks due to syslog() | Sebastian Huber | |
Update #3419. | |||
2018-05-02 | ftpd: Fairplay with libbsd | Sebastian Huber | |
Update #3419. | |||
2018-02-07 | ftpd: Use self-contained synchronization objects | Sebastian Huber | |
Update #2843. | |||
2018-01-25 | Remove make preinstall | Chris Johns | |
A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254. | |||
2017-12-13 | ftpd: Include <rtems/ftpd.h> | Sebastian Huber | |
Prepare for header file move to common include directory. Update #3254. | |||
2017-07-18 | ftpd: Use floating point tasks | Sebastian Huber | |
Update #3076. | |||
2016-03-18 | ftpd: Resolve function name conflict | Sebastian Huber | |
Visible with Newlib be657151f12f4d198e45395987f0a626ee1bbb91. | |||
2015-10-26 | basdefs.h: Add and use RTEMS_UNUSED | Sebastian Huber | |
2014-08-29 | Regenerate all preinstall.am files. | Chris Johns | |
With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash. | |||
2014-08-28 | Regenerate all preinstall.am files. | Joel Sherrill | |
Apparently, at some point automake output changed and these were not updated. | |||
2013-02-13 | ftpd: Go back to the root directory | Sebastian Huber | |
2013-01-30 | ftpd: Check the root and current directory change | Sebastian Huber | |
Only continue the session if the root and current directory change was successful, otherwise the FTP server may access restricted file system areas. | |||
2012-11-21 | ftpd: Add SIZE command | Sebastian Huber | |
2012-05-29 | ftpd: Set current directory after session close | Sebastian Huber | |
The chroot() is an implicit chdir("/"). Set the current directory to "/" after session close. This helps to avoid references to mounted file systems in dynamic media. | |||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | |
2012-02-02 | PR 1998/networking - Move ftpd root initialization | Joel Sherrill | |
From: Xiangfu <xiangfu@sharism.cc> Signed-off-by: Xiangfu <xiangfu@sharism.cc> | |||
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | |
2011-12-08 | 2011-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* ftpd/ftpd.c: Make split_command static. | |||
2011-10-26 | 2011-10-26 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | |
* ftpd/ftpd.h, ftpd/ftpd.c: Moved buffer and stack size constants into header file. | |||
* ftpd/ftpd.c: Increased data buffer size to 4096 bytes. Use RTEMS_MINIMUM_STACK_SIZE plus the data buffer size for worker thread stack size. | |||
2011-07-24 | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | |||
2011-06-24 | 2011-06-24 Arnout Vandecappelle <arnout@mind.be> | Sebastian Huber | |
Sebastien Bourdeauducq <sebastien@milkymist.org> PR 1724/cpukit * ftpd/ftpd.h, ftpd/ftpd.c: Added USER/PASS authentication. | |||
2011-06-07 | 2011-06-07 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | |
PR 1811/networking * ftpd/ftpd.c: Fixed reply format. | |||
2011-04-04 | 2011-04-04 Sebastien Bourdeauducq <sebastien.bourdeauducq@gmail.com> | Joel Sherrill | |
PR 1722/networking * ftpd/ftpd.c: FTPD fails to parse correctly FTP commands relating to filenames with spaces in them. | |||
2011-02-23 | 2011-02-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* ftpd/ftpd.h: Add missing includes. | |||
2010-05-07 | 2010-05-07 Arnout Vandecappelle <arnout@mind.be> | Sebastian Huber | |
PR 1511/networking * ftpd/ftpd.c: Abort RETR for directories. | |||
2010-03-12 | 2010-03-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c, httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c, libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c, libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c, libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c, libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c, libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c, libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_init.c, libnetworking/libc/res_query.c, libnetworking/rtems/rtems_mii_ioctl.c, score/src/objectgetnameasstring.c: Readdress use of ctype methods per recommendation from D.J. Delorie on the newlib mailing list. We should pass an unsigned char into these methods. | |||
2010-03-11 | 2010-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* ftpd/ftpd.c, httpd/uemf.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c, libblock/src/diskdevs.c, libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c, libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c, libmisc/uuid/parse.c, libnetworking/lib/ftpfs.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_network.c, libnetworking/rtems/rtems_mii_ioctl.c, score/src/objectgetnameasstring.c: Fix warnings for ctype methods. | |||
2009-03-12 | 2009-03-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* ftpd/ftpd.h: Add extern C. |
