summaryrefslogtreecommitdiff
path: root/cpukit/doxygen (follow)
AgeCommit message (Collapse)Author
2020-10-08doxygen: Add "Generated from ..." commentsSebastian Huber
Improve file header comment. Update #3994.
2020-09-28doxygen: Fix use of getchark() and rtems_putc()Sebastian Huber
2020-09-18doxygen: Wrap long linesSebastian Huber
2020-09-17validation: Add general purpose test suiteSebastian Huber
Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959.
2020-09-17doxygen: Move top-level group definitionsSebastian Huber
Update #3959.
2020-09-17rtems: Add rtems_task_construct()Sebastian Huber
In contrast to rtems_task_create() this function constructs a task with a user-provided task storage area. The new directive uses a configuration structure instead of individual parameters. Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a task storage area based on the task attributes and the size dedicated to the task stack and thread-local storage. This macro may allow future extensions without breaking the API. Add application configuration option CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS Workspace size estimate. Update #3959.
2020-09-17CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZESebastian Huber
Add this application configuration option. This configuration option can be used to reserve space for the dynamic linking of modules with thread-local storage objects. Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a thread-local storage size. Update #4074.
2020-08-07Document application configuration optionsSebastian Huber
Add a new directory for Doxygen-specific documentation content. Add a Doxygen only header file containing documentation of the application configuration options. The header file is generated from specification items. Close #3994.
