Update via:
wget -O config.guess 'https://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD'
wget -O config.sub 'https://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD'
Update #3433.
Update via:
wget -O config.guess 'http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD'
wget -O config.sub 'http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD'
* .gitignore: Remove config.guess, config.sub, missing, install-sh.
* config.guess, config.sub, missing, install-sh: New.
* config.sub: Remove (Automatically added by automake, again).
* bootstrap: Reflect change above.
* configure.ac: Require automake >= 1.7.6.
* config.sub: New from subversions to accomodate c4x/tic4x.
* bootstrap: remove/add automake added files.
* .cvsignore: reflect changes to bootstrap.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* config.guess, config.sub: Update from CVS-autoconf to pick
up new features (e.g. CC_FOR_BUILD in config.guess) but is
necessary anyway to use autoconf-versions > 2.13.
* config.sub: Added or16 and or32.
I am not sure if this is related to this problem, but here is an observation:
All config.sub scripts from rtems' intrastructure packages internally
transform i386-rtems into i386-pc-rtems
newlib-1.8.0-rtems/config.sub i386-rtems --> i386-pc-rtems
egcs-1.0/config.sub i386-rtems ---> i386-pc-rtems
egcs-1.0.1/config.sub i386-rtems ---> i386-pc-rtems
bintutils-2.8.1.0.19/config.sub i386-rtems ---> i386-pc-rtems
gas-98xxxx/config.sub i386-rtems ---> i386-pc-rtems
The only exception is rtems itself:
rtems/config.sub i386-rtems ---> i386-rtems
I am not sure if this influences i386-rtems + c++/posix, but this indicates
that rtems' config.sub script should to be updated.
To fix this, simply copying config.sub e.g. from egcs and removing all
i[3456]-rtems* case statement lines from configure.in should be sufficient.
BTW, from autoconf's point of view i386-pc-rtems is the correct target
conforming autoconf's naming conventions, but using i386-rtems for all
packages (infrastructure and rtems) should make no difference.
enclose.
be resolved.
