2020-10-12 | lm3s3749-testsuite.tcfg: Add spcxx01 | Joel Sherrill | |
2020-04-07 | lm4f120-testsuite.tcfg: Add psxsignal07 | Joel Sherrill | |
Updates #3938. | |||
2020-03-12 | lm3s3749-testsuite.tcfg: Add ttest01 | Joel Sherrill | |
2019-05-14 | bsps/arm: Adjust machine flags for ARMv7-M | Sebastian Huber | |
Update machine flags for Cortex-M3 and Cortex-M4 based BSPs to account for Cortex-M3 Errata 602117 which required GCC multilib changes. Update #3747. | |||
2019-03-13 | bsp/lm3s69xx: Fix typo in test configuration | Sebastian Huber | |
2019-03-12 | lm4f120-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | |
small memory | |||
2019-03-12 | lm3s6965-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | |
small memory | |||
2019-03-12 | lm3s3749-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | |
small memory | |||
2019-03-04 | bsp/lm4f120: Disable unsupported tests | Sebastian Huber | |
2018-11-28 | lm3s3749-testsuite.tcfg: Add dl07 | Joel Sherrill | |
2018-04-23 | bsps: Move make/custom/* files to bsps | Sebastian Huber | |
Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285. |
