summaryrefslogtreecommitdiff
path: root/bsps/arm/include/bsp/arm-a9mpcore-start.h (follow)
AgeCommit message (Collapse)Author
2020-10-16bsps/arm: Add workaround for Errata 794072Sebastian Huber
Add a workaround for Cortex-A9 Errata 845369: A short loop including a DMB instruction might cause a denial of service on another which executes a CP15 broadcast operation. Close #4115.
2020-10-16bsps/arm: Workaround for Errata 845369Sebastian Huber
Add a workaround for Cortex-A9 Errata 845369: Under Very Rare Timing Circumstances Transition into Streaming Mode Might Create Data Corruption. Update #4115.
2020-10-05bsps: Break out AArch32 GICv3 supportKinsey Moore
This breaks out AArch32-specific code so that the shared GICv3 code can be reused by other architectures.
2019-03-08bsps: Adjust shared Doxygen groupsSebastian Huber
Update #3706.
2018-07-25_SMP_Start_multitasking_on_secondary_processor()Sebastian Huber
Pass current processor control as first parameter to make dependency more explicit.
2018-07-05bsps/arm: Include missing header fileSebastian Huber
2018-01-25Remove make preinstallChris Johns
