This helps to make the build reproducible.
If the CSafeLoader is available, load only the necessary build items.
This considerably speeds up the build setup time if the CSafeLoader is
used.
This makes it more obvious that this is an item UID.
Move the item cache handling to a ItemCache class. Implement this class
depending on the availability of CSafeLoader.
The CSafeLoader uses the C libyaml libary to considerably speed up the
loading of YAML files.
These memory benchmark programs are not supposed to run. Instead, they
can be analysed on the host system to measure the memory usage of
features. See the membench module of rtems-central.
Update #3716.
Replace the main page with a high level description of the RTEMS feature
set similar to:
https://docs.rtems.org/branches/master/user/overview/index.html#features
The replaced content can be found in the RTEMS Classic API Guide:
https://docs.rtems.org/branches/master/c-user/overview.html
https://docs.rtems.org/branches/master/c-user/key_concepts.html
Update #3705.
Document that the build scripts in the testsuites produce a test program.
The ARM926EJ-S is an ARMv5T architecture processor and lacks some
features of ARMv6 processors such as the ARM1176JZF-S.
Close #4940.
Update #3767
Print the full test information.
Increase stage 2 bootloader size to 16MiB.
These comments duplicate the memory and region definitions of the linker
command file.
This implementation disables the MMU during the modification of the
translation table. This behaviour is required by boot loaders for these
boards.
The type is a pointer.
This fixes test failures on targets using short enums.
Update #3716.
Make sure we have enough POSIX key value pairs available. This fixes a test
failure on some targets.
Make objects and functions static. Initialize variable to get rid of warnings.
Replace --rtems-version with a PROGRAM_PREFIX option. This allows also
the use of vendor tools.
Fixes the following Coverity warning:
** CID 1539495: Integer handling issues (CONSTANT_EXPRESSION_RESULT)
/bsps/shared/dev/rtc/mcp7940m.c: 317 in mcp7940m_set_time()
Basically coverity warns that (buf[...] & 0x7) can't be bigger than 7.
Just remove the unnecessary comparison.
Define the RTEMS version in the wscript. Optionally use a VERSION file
to change the default values of the wscript. Allow the command line
option --rtems-version to override __RTEMS_MAJOR__. Remove support for
command line configurable options (--rtems-option).
Rename internal define RTEMS_VERSION_VC_KEY to
RTEMS_VERSION_CONTROL_KEY.
This reverts commit 26d50bdfb601b9ef71ec2b30d2d9467c2437f443.
This allows to use a I2C RTC together with this BSP.
The MCP7940M is a I2C RTC chip. The new driver uses the dev/i2c API to
support the RTC. It is written with the intention, that the driver can
be adapted to other RTCs with a similar register layout by just
replacing the initialization function.
Based on:
commit 99494370d6124ef5d773119fa59f5bac4bbf395f
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Wed Mar 4 12:34:34 2020 +0100
bsp/stm32h7: New BSP
Update #3910.
Inspired by:
commit fe58f6ce4bf1ff5e92d64b9fee0cb46b6ac06e64
Date: Thu Nov 26 08:13:52 2020 +0100
bsp/stm32h7: Add and use BSP Doxygen group
Update #3910.
Part of the new HAL requires float_t type definition. For that it includes
math.h header file which unfortunately brings a lot of math functions in.
One of them, 'log' conflicts with FreeBSD log function defined in systm.h
Provided hack is really just a crude work around this issue. Never thought
that Motorola 68881 would help me even in 21st century.
