2020-12-15 | build FIXME add taskexit.cqual-9 | Sebastian Huber | |
2020-12-15 | Adds four test runner files, all work | Andrew Butterfield | |
2020-12-15 | Adds model-events-mgr test to model-0 testsuite | Andrew Butterfield | |
2020-12-15 | validation/ts-model-0: Add test suite | Sebastian Huber | |
2020-12-15 | FIXME ISR_LOCK_MEMBER() confuses Doxygen | Sebastian Huber | |
2020-12-15 | cpukit/include/rtems.h | Sebastian Huber | |
2020-12-15 | cpukit/include/rtems/irq-extension.h | Sebastian Huber | |
2020-12-15 | cpukit/include/rtems/rtems/mainpage.h | Sebastian Huber | |
2020-12-15 | validation: Add tests for basedefs.h | Frank Kühndel | |
These are validation tests for cpukit/include/rtems/score/basedefs.h. tc-basedefs.c is automatically generated from the new verification item in rtems-central repository file spec/rtems/basedefs/val/basedefs.yml. These tests shall verify the requirements in spec/rtems/basedefs/req/*. The other two files are manually created. They are needed as some of the tests require items being defined in another compilation unit. Note: There are already unit test for basedefs.h in testsuites/sptests/spmisc01/init.c. | |||
2020-12-15 | validation: Add tests for Partition Manager | Sebastian Huber | |
2020-12-15 | validation: Add tests for task modes | Sebastian Huber | |
2020-12-15 | validation: Add tests for options | Sebastian Huber | |
2020-12-15 | validation: Add tests for attributes | Sebastian Huber | |
2020-12-15 | validation: Add tests for Event Manager | Sebastian Huber | |
2020-12-15 | validation: Add tests for object name to id | Sebastian Huber | |
2020-12-15 | build FIXME remove some header files from qual | Sebastian Huber | |
2020-12-15 | build FIXME task create, measure runtime | Sebastian Huber | |
2020-12-15 | build FIXME objrtemstestnoqual | Sebastian Huber | |
2020-12-15 | build FIXME librtemscxx | Sebastian Huber | |
2020-12-15 | build FIXME install test executables | Sebastian Huber | |
2020-12-15 | build FIXME coremsg | Sebastian Huber | |
2020-12-15 | build FIXME rtems_printf() -> qual | Sebastian Huber | |
2020-12-15 | build FIXME pre-qual | Sebastian Huber | |
2020-12-15 | build FIXME test noqual | Sebastian Huber | |
2020-12-15 | build FIXME obj no prot | Sebastian Huber | |
2020-12-15 | build FIXME qual extension delete etc | Sebastian Huber | |
2020-12-15 | build FIXME add some delete directives | Sebastian Huber | |
2020-12-15 | build FIXME add termios to qual for arm | Sebastian Huber | |
2020-12-15 | build: FIXME introduce pre-qualified parts | Sebastian Huber | |
2020-12-15 | validation: Add space profile testsuite | Sebastian Huber | |
2020-12-15 | build FIXME realview_pbx_a9 | Sebastian Huber | |
2020-12-15 | build mallocinitone leon3 | Sebastian Huber | |
2020-12-15 | libc: Optimize malloc() initialization | Sebastian Huber | |
Change licence to BSD-2-Clause according to file history. | |||
2020-12-15 | build wkspaceinitone leon3 | Sebastian Huber | |
2020-12-15 | score: Optimize Workspace Handler initialization | Sebastian Huber | |
2020-12-15 | build wkspace split | Sebastian Huber | |
2020-12-15 | score: Split wkspace.c | Sebastian Huber | |
2020-12-15 | wkspace.c: Change license to BSD-2-Clause | Sebastian Huber | |
Change licence according to file history. Update #3053. | |||
2020-12-15 | unit: Add test for misaligned builtin memcpy() | Sebastian Huber | |
2020-12-15 | testsuites: Add testsuite for unit tests | Sebastian Huber | |
2020-12-15 | rtems: Generate <rtems/rtems/tasks.h> | Sebastian Huber | |
Change license to BSD-2-Clause according to file histories and documentation re-licensing agreement. Update #3899. Update #3993. | |||
2020-12-15 | rtems: Generate <rtems/rtems/support.h> | Sebastian Huber | |
2020-12-15 | rtems: Generate <rtems/rtems/signal.h> | Sebastian Huber | |
2020-12-15 | rtems: Generate <rtems/rtems/sem.h> | Sebastian Huber | |
2020-12-15 | rtems: Generate <rtems/rtems/region.h> | Sebastian Huber | |
2020-12-15 | rtems: Generate <rtems/rtems/ratemon.h> | Sebastian Huber | |
2020-12-15 | rtems: Generate <rtems/rtems/mp.h> | Sebastian Huber | |
2020-12-15 | rtems: Generate <rtems/rtems/message.h> | Sebastian Huber | |
2020-12-15 | rtems: Generate <rtems/rtems/intr.h> | Sebastian Huber | |
2020-12-15 | rtems: Generate <rtems/rtems/dpmem.h> | Sebastian Huber | |
